AlfaOBD
John Owen
Mesa, AZ
Cummins
has anyone gotten the auto mirror fold on lock (keyfob button) working yet? or is that just specific to jeeps?
No, it doesn’t work with Alfa. That only way is via an OBD plug called Tazer I believe. You should be able to search Tazer on here for more info.
AZJohnnyO
FXCLM5
2017 Laramie CC
ED 3.0 V6
AZJohnnyO
thank you
Lawsuit11
Fort Worth, TX
Hey guys and girls, this is the very first thing I enabled with AlphaOBD. It's a great tutorial for first timers. Not sure why it took me so long to share it.... Enjoy and happy modding!
Sent from my LG-LS995 using Tapatalk
Looks like you’re one of the few that it works to roll them down all the way. My 2018 hates it and only works like 25% of the time. It usually stops 3 times lol to get them rolled all the way down
big daddys house
Hill Valley
Really!!!
I'm assuming you've changed the batteries in your remote???
FXCLM5
2017 Laramie CC
ED 3.0 V6
my 17 rolls down 25% i thought it was programmed to do that first initial attempt of holding the unlock for roll down?
DBLJ
Corpus Christi
Diesel 6.7
Connect to the abs > continental abs > I believe it's clearing rolls test then possibly static ecu. That should clear everything up. If you still have codes check the body Computer and engine computer for codes. This should possibly correct the speedo. If not try again following the instructions on post 1. Find my name and open the Google drive link. There is step by step instructions with pictures.
As far as seeing the changes in the body Computer logs I don't think he's fixed that yet. I haven't tried since a couple updates ago.
2018 2500 6.4L Tradesman[/QUOTE
DBLJ
Corpus Christi
Diesel 6.7
Thank you! I will try what you said after work tomorrow. Now the def 100% full is on and im guessing its because the speedo isnt working and shows still @100% full.
DBLJ
Corpus Christi
Diesel 6.7
Thank you! I will try again when i get home from work tomorrow.
chri5k
USA
Diesel
Ok guys. So still having trouble with my friends tow mirror install on his 2013 1500 tradesman. Used alfaobd to turn on the tow mirrors present, approach lights, and turn signals. Everything works but the approach lights. Took it to the dealership last week to get a recall fixed. The service guy told him the computer was shutting the approach light due to not recognizing led voltage. (Not sure if that is exactly right) he tried to get more info from the guy but the service tech told him it would need to be put on the computer and cost him more money to get more info. I'm stuck on what to do next. Any help is greatly appreciated.
Are they aftermarket mirrors? If so, there are a few Chinese manufacturers that reverse the leads for the LED's. I had a set of YITAMOTOR mirrors where the wires on the second (white ) connector had to be reversed to get the light to work. The wires were REd and BLUE IIRC.
FXCLM5
2017 Laramie CC
ED 3.0 V6
I found a old Post in a fiat500 forum in 2014 that says alfaobd can check the # of flash counts that has been done.
Anybody have more info on this?
DBLJ
Corpus Christi
Diesel 6.7
Screenshot_20190813-182342_AlfaOBD.jpg Screenshot_20190813-182342_AlfaOBD.jpg
