AlfaOBD
1500ram12
5.9L Cummins
14 truck with a 14 cluster
and I dont even care about changing the hours I'd just be happy with the mileage
It's possible that this current updated messed with the mileage correction. I believe on post 1 there may be a link for past versions. If not I will try and send you the known working versions apk file to download
2018 2500 6.4L Tradesman
drprymer
That would be great I appreciate it
Lawsuit11
Fort Worth, TX
It’s on post one look for my name and past Alfa apk version all are available
You might have to contact the Dev for an activation code since you’re going backwards in versions.
drprymer
It’s on post one look for my name and past Alfa apk version all are available except the current version of Alfa
I sent an email to them. Hopefully ill be able to figure out how to use the apk stuff
Lawsuit11
Fort Worth, TX
Download the apk. Open your file manager on android and open the the file, it will prompt you from there on what to do
Alexx
Los angeles ca
Has anybody found a bypass harness for 2019 rams new body and tried makin any changes?
1500ram12
5.9L Cummins
I believe that the 2018 2500 harness works on the 2019 classics and with trimming of one of the connectors works on the 2019s. I'm pretty sure @DeereGuy @M2Mods is or has made harnesses for the 2019s. The classics if I remember right have the same programming as the 2017+. 2019s I think a few people have tested and activated a few things with alphaobd.
drprymer
I talked to Alexey and its definitely my cheap adapter that's making it not work. I just ordered a MX+ so ill try again on Monday when it comes in.
1500ram12
5.9L Cummins
If you haven't send a debug file to him. He will be able to figure out what changed
Lawsuit11
Fort Worth, TX
Yeah it could have the correct pins for the BCM connection but there could be one pin out of place for the EVIC that’s cause it not to write to the evic.
chrisbh17
The funny thing is each of these connections only uses 2 pins out of 16 (I think) that are in the connector.
The good adapters (like the OBD MX) can switch between the 2 sets of pins necessary to connect to different CAN modules....the cheap ones require wiring adapters to go between the OBD adapter and the data link socket.
If you add up the cost of one or two adapters and a cheap OBD adapter, you are pretty close to buying an OBD MX anyway.
CincyCuda68
Ohio
The 2018 2500 harness works for 1500 5th gen, don’t thing it works for 5th gen 2500. Though the security harness works on a 5th gen use Alfa at your own risk as it hasn’t been tested much in them.
If it’s a classic then treat it as a 2018
krakaman24
2018 Ram 2500 6.7L CTD
Colorado
CTD 6.7L
Has anyone had this error while trying to connect to Google Drive? I can verify through my Google Drive that AlfaOBD has permission and is connected to my account but it won't let me save anything saying that login is required. 410fab3d45bfe83b50b263ca699c8f7d.jpg
Parker675
Dallas GA
I'm having the same problem today. I'm using OBDLink MX latest firmware on everything. I was able to set the mileage but hours keeps telling me procedure failed. Tried over 10x.
big daddys house
Hill Valley
Mine said failed to. I just turn the key off, let the truck rest for five minutes and it worked.
I explain it here
Sent from my LG-LS995 using Tapatalk
Parker675
Dallas GA
I followed your video exactly but mine never corrects or changes just says failed and all show the same. I also lost the option to take the decimal off my odometer showing does anyone know how to get it back?
SRich2015
USA
It may be on here but can't find it!!! Used my windows alfaobd today (first time in months) to program some new headlight features and noticed that it was not keeping a Log of my changes as hit has always worked in the past!! Alfa auto updated before I started just wondering if this is a new issue!! Thanks edit: got it fixed!!
Parker675
Dallas GA
I explain it here
Just used the previous version of the app and still the same. Says procedure failed just like yours but when I go back after 5 minutes the hours still aren't corrected....2013 2500 with a 2013 cluster if that helps.
big daddys house
Hill Valley
Hey guys.... Anybody else have trouble with a 2013 evic? I know they are slightly different then 2014 and up.
I would send debug file sir.
