AlfaOBD
Parker675
Dallas GA
I've tried the current version and the one you're using. Working with the dev now. Sent him a few debug logs.
slag009
Palm Harbor, FL
Hey guys.... Anybody else have trouble with a 2013 evic? I know they are slightly different then 2014 and up.
I would send debug file sir.
Sent from my LG-LS995 using Tapatalk
It was hit or miss for me. I have two 2013 evic clusters and one would not change either of the hours but did not try the milage. The other one allowed me to change the milage and the total hours but not the idle.
1500ram12
5.9L Cummins
Someone with a 2017 truck and cluster can't program his either
2018 2500 6.4L Tradesman
Parker675
Dallas GA
Mileage went through first time for me. Said failed but still went in. None of the hours are changing though no matter what I try.
Lawsuit11
Westland, MI
I have a 17 cluster in my 18 and programmed it perfectly fine with Version 2.1.7.1 mileage. Hours
Parker675
Dallas GA
Found your post with the old apk but it just downloads as files wont install as an app.
Lawsuit11
Westland, MI
Yeah you have to open the file up in your file manager to get it to download on an android cause it’s an APK
Killerb
Painted post
Ram 2500
Did get a failure on app when adjusting total engine Life however everything went through fine.
Not exactly sure on yr of cluster just know it works in my 18' Ram without an issue.. yet.
2.1.7.4 app version
twizt3dkitty
Earth
I tried doing a search through the post but couldnt find the specific information. I have a canadian 2018, but live in us. Long story, bought it imported undisclosed. I'm having issues with sirius in that the travel link constantly shows unsubscribed on the radio, but subscribed on my sirius account. Sirius is basically no help, all they do is send refreshes that do nothing. They think the issue may be my account with them is us based, but the radio esn comes up canadian. (UAQ obviously) I'm wondering if the problem is possibly that the travel link is not enabled in the bcm. I think I read that is a possibility. Does anyone have any advice for me? If I need to buy alfa so be it, but as I would also need a security harness and an obd mx, this is alot of money to just see if this is it. I'm hoping there may be an alternative. My local dealer is useless, they hate me because the truck is canadian.
Sent from my SM-N975U using Tapatalk
chrisbh17
There is a setting in Alfa regarding Travel Link (ECUConfig 3 - SDAR Travel Link Present)
I dont know what (if any) difference it makes, but there is definitely one in there.
Lawsuit11
Westland, MI
If you have the Sirus travel link option in the actual menu for your radio it’s enabled. Should say Sirus travel link. Where you can view weather sports etc. Not the one for the Sirus radio. If you need to enable it you will need to use AlfaOBD
