AlfaOBD
diboblo
California
Off road pages?? I know alot of ppl wanted the srt pages and theres a million warnings about not enabling them... not sure why that is either...
But what are off road pages.
Sent from my SM-N975U using Tapatalk
Jeep Grand Cherokee:
Elevation
All axles position
Wheel slippage
Differential & rear end info
Gauge info (similar to Performance Pages)
Incline & tilt angles
Bob
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
- Jeep 8.4 uConnect offers an off road pages/section...
- Challenger, charger, viper, SRT Cherokee offer SRT Performances pages
** The catch is tricking the radio into thinking it's in one of those vehicles so it will display the related info/pages WITHOUT messing the entire truck up. A few people tried it early on and found out that certain vehicle line/brand/model settings are interconnected with other BCM settings and messed up their truck quite a bit... Had to go to the dealer for a reflash or spent several days comparing their original saved settings on gDrive to figure it out.
It might be possible that a seperate module between the truck and the radio could get it to do what you want like Customtronix ' Enzo /Enigma but I don't know if they have that as an option. (They used to be able to do it with custom software load on the radio)
M² Mods.
dracman
canada
2011 ram 1500 reg cab.dads ol truck
hey guys got 2017 ram express and did 7"cluster swap got the engine hours and idel hours but the app dont show the odometer milage change i updated it no go also downloaded the free one and was there but wort work cause its the free one. i need 2.1.7.3 i got 2.1.6.8 dont know whats up mabe tablet to old lol dont know
KC Cryptkeeper
KCMO
2015 Ram1500
I run my alfa on 6 year old nexus 7" tablet, I don't think that is your problem. Looks like you need to update the software and get rid of the free version.
dracman
canada
no i got the full for over a year now but it wont update all the way i downloaded the free one the see if the milage one was on there
dracman
canada
Needs to update more then this
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
Mine is 2.1.7.6 for Alfaobd updated 10/7
dracman
canada
I don’t know why it won’t update am I doing something wrong
dracman
canada
think i might have got it fingers crossed
1500ram12
5.9L Cummins
Are you connected to the instrument cluster? Not the body Computer
Edit never mind looks like you are
2018 2500 6.4L Tradesman
dracman
canada
still wont go but got idel hours and drive hours but mileage wont go.gonna let it sleep all night
Austen
Missouri
I installed & activated OEM remote start with the kit from my dealer two days ago on my truck and it works great but I had a few questions. Not sure if there are any other settings other than what I have posted but I am wondering if anyone knows what I need to enable with Alpha to get all CSM that are in the radio when you have factory remote start. Picture is from my fiancees Grand Cherokee. @Ghost_RAM would you happen to know any CSM that need to be enabled in order to show any remote start settings in the radio? 668063d043ba51d1c40b4c3c454e4a7d.jpg
17' CCSB 4X4 68RFE 2500 6.7 Tradesman DRP EGR delete, CTT tuning w/TCM tuning, UAQ w/7 speed HVAC, 7" premium EVIC, OEM front Parksense, OEM style front camera, aux switches
RamAz
Having some issues finding where I messed up on alfaobd. I only have two remaining warnings. T/C and Service Brake. Can’t figure out where I went wrong. Looking for someone who may possibly have another ram 1500 Hemi express that could compare logs with.
1500ram12
5.9L Cummins
I think there is some logs on post 1 with a few different trim levels and year's
JMod45
TX
6.7 Diesel
I did the RF hub unlock/reset with my pin. I set it for 45psi but it shows 63psi max as the result. So I put 63psi, 80psi, 58psi and none of them make the warning going away
I was just trying to update my thresholds and the numbers are all over the place. 38 sets them to 58 I believe, 60 set them to 71, no rhyme or reason to what's going on.
I changed them a few months ago with no problems, so I'm thinking something in the app has changed.
2014 Ram 2500, I tried resetting the rf hub, but that didn't improve anything.
**** UPDATE ****
I installed AlfaOBD on one of my old phones a while back. Just pulled that phone out, and was able to change the thresholds correctly.
Version that worked is 2.1.7.3
Current version that isn't working is 2.1.7.6
Tucker
Evergreen, Colorado
3.0 Ecodiesel
Hello all,
A lot of great information on this huge thread but there are a few questions I have.
1. I have stock projectors and turned on the DRLs. The DRLs are working just fine but the option to turn them off on the radio is not there. Not a huge deal, I'd still rather have the DRLs working but having the option to turn them off real quick would be a nice bonus. I have seen on this thread that some other people have had this same issue and that it can just take a few cycles of running for it to turn on. Is this true? I have gone to the post on this thread with all the functions that need to be changed and double checked mine. They are all changed correctly.
2. Does anybody know if you can make the radio go to the navigation map by default rather than have to go to nav and then hit map?
3. Is there a way to display the gear select all the time or no? I did find a setting under ECM Config 4 - Gear Display and tried it but it did not do anything. Is there maybe another setting I have to change to get this to work?
TIA!
