AlfaOBD
joelmic
stl mo
2017 Ram 1500 Express Quad Cab 3.6L 4x4 20x9 Wheels
Where is that battery info again??? I forgot how to get to it
ManualCummins
Cummins 6.7
As you all know I’ve been working hard on building remote start so I came up with a pretty ingenious solution
That allows you to use the factory hood switch without buying the remote start kit saving you hundreds of dollars That allows you to use the factory hood switch without buying the remote start kit saving you hundreds of dollars
I can make the Wiring harness for you for 50
You can get a good switch for $30
Oem remote start for under 100
The only other peace u need is the key inlay
hopkinslarry
Ozarks
I have been attempting to change the mileage and engine hours on the 7” evic cluster with no success. I have attempted at least a dozen times. Alpha takes me through the steps Even to the point that the continental
Screen tops up but no changes appear. Donor truck 2017 2500 6.7. My truck 2018 6.7
Could it be in the bypass. Using AlphaOBD MX+
Sam Ram
Tottenham
EcoDiesel 3.0L
I personally haven't tried it on a 19 classic . But I'm about to for a guy.
Please keep me updated I would appreciate that.
I'm just realizing that while working on a 19 classic DS yesterday I was using 19 DT. So I'm not so sure it matters because I was successful with DT on a DS
Sent from my SM-G965W using Tapatalk
Hey Aimvee, it worked using the Powernet 2019+ and following the rest of the instructions here on the site.
SitKneelBend
St. Louis
3.6 Pentastar
If you have a friend with an earlier 4th gen you can try it in their's if they'll let you?
hopkinslarry
Ozarks
My Alpha OBD does not offer a powernet 2019+ option. I'm kinda new at this, that is what your talking about right?
SRich2015
USA
Are you updating it. Mine is set to auto update!!
Sam Ram
Tottenham
EcoDiesel 3.0L
Yeah mine has it. You might need to update your AlfaOBD software. I just got it maybe a month ago. It also has also the following:
- MY2019 POWERNET
- MY2020 POWERNET
- DT MY2019 POWERNET Var.1
- DT MY2019 POWERNET Var.2
- DT MY2019 POWERNET Var.3
- DT MY2019 POWERNET Var.4
- DT MY2020 POWERNET
Hassan
Türkiye
hello everyone i'm new here uconnect i have 8.4 screen i want to open cargo camera what should i do
I want to watch the rear camera and cargo camera on the road, how can I do them I am using alfaobd
RamCares
n/a
n/a
Hi, I'm sorry to hear this. Please let me know if you plan on visiting a dealership for this concern. I would be happy to open a case for you.
Alison
RamCares
k_gomez17
Colorado
Ecodiesel
Does anyone by chance have original BCM settings for an ecodiesel with factory enter n’ go and factory remote start they’re willing to post?
Cornholio
N Ft Myers, Fl
I don’t know if this was posted but I changed the acceleration factor from 5 to 3 and it made a big difference. I know some people go and buy peddle commander or something like that but it made a difference might try to go to 1 and let it rip lol!!
I read that going to 7.5 was the way to go but I only noticed a difference during one drive. The pedal commander has my brain going in overdrive trying to figure out how it works. It has to manipulate where we can with alfa, but just what is it manipulating? It's driving me nuts, I'm spending about 8 hours a day trying to figure this crap out!
mrugg
6.7 cummins
I apologize before I'll ask the question because I'm sure it has probably already been asked but I could not find a straight how to on it. So here goes.
I need to learn how to program a new key for a 2017 Ram 1500 bighorn. The truck only came with one key and my dad would like to get a spare key made. So like I said above he only has the 1 original key and a key to program and I wanted to help him out and thought that the alfaobd could do this.
Sent from my SM-T387V using Tapatalk
Dannyn_01
Long Island NY
HEMI 5.7
The first page has the info you need, here’s the link.
https://www.ramforum.com/posts/1864604/
1500ram12
5.9L Cummins
Thank you very much.
What is the name of the4 pin code to ask for at the dealership
Sent from my SM-G977U using Tapatalk
Rf hub pin.
If the dealer won't give it to you or wants more than $15 you can use a app called Chrysler pin puller. It'll cost about $15 for "tokens" but you'll get it immediately. Many members have used it
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
mrugg
6.7 cummins
Rf hub pin.
Thank you for the heads up on that.
