Alignment issue?
Mikeyatc
Cummins
I have a 2014 3500 long bed diesel. It constantly pulls to the right. I have brought it back to the dealer 3 times. They say it's "in alignment" and it pulls to the right because it is sensitive to the crown of the road. Has anybody experienced this?
CherryRed
South West Virginia
There are other issues that can cause a pull. Check the condition of your tires, air pressure, etc. Are the brand/model of the front tires identical? You can also try swapping the front tires (left to right/right to left). Get the right front tire off the ground and give it a spin. Check for dragging brake, loose wheel bearing, etc.
cc rider
Western NY
I just posted about my dealer not being able to get it right. After 3 tries, they finally got it. It was the same "tech" doing it. He told me u cant just pull the steering wheel off and set it like the old days? arent alignments only covered for a year along with brakes, etc? so not sure if its under warranty. Someone correct me if im wrong. If it is , take it back and get loud, but not obnoxious
