alignment parts
mopar68
Wisconsin
I have a 2014 Outdoorsman 1500 and the alignment is maxed out . What parts do I need to replace to bring them back in ?
indept
South Jersey
How do you know the alignment is maxed out?
jawzs2
Air Force
South Jersey
What is maxed out? caster, camber, toe-in, toe-out? I'd do as recommended above, if they can't tell you, find a different shop.
Dodge trucker
Kankakee il
One comment I have to make here
I see a lot of posts on car/ truck sites specifying "LE", "SLT", "outdoorsman", "tradesman",etc... 99%of the time the trim level of ones truck has no bearing on the question at hand so don't get hung up on it. In this case there's no difference in suspension on an "outdoorsman" vs a "tradesman" or " Laramie" etc but there are differences between 1500, 1500,etc.
Dodge trucker
Kankakee il
When I had my 12 aligned I was charged extra because my cam bolts were seized and it took the guy linger than "usual" to get them broke loose and able to be adjusted. I was an alignment guy for nearly 20 years and wouldn't want to go back to it with all the extra crap that I didn't have to deal with... (Yaw sensor, (what's that?) Steering angle sensor, etc ..)
