Alignment specs for 2/4 drop
myoung84
Tulsa, OK
2012 Power Wagon
I will be putting on my 2/4 Belltch drop kit this Saturday and will obviously have to have it aligned. What would be the best specs to align the front to other than stock? Maybe add a little more negative chamber? I drive the truck pretty hard and the outside edges of my tires show it, they are worn down a lot more than the inside edge, and I rotate every 5-6k miles.
Here are the specs from when I got it aligned after my front lift. They told me it was maxed out on the chamber and they could not bring it in any more. I'm sure the slight positive chamber does not help on the outside edge tire wear.
https://dl-web.dropbox.com/get/Public/Alignment.pdf?w=cbb07533
myoung84
myoung84
Tulsa, OK
2012 Power Wagon
It rides great! It's a little stiffer of course, but handles much better. I even had it loaded down to the max last week with my 4 wheeler in the bed and boat hooked up (Over 1000 lbs total) and it handled the load very well with my airbags at 35 psi.
I did have to get the alignment done twice. After about 200 miles on the first alignment my front tires were feathering. My toe had shifted quite a bit but they got everything straightened out with -0.5 degrees of chamber.
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
I need to take mine back in for another tweak or two as well.
These trucks ride great with a 2/4. So much so that I don't want to cut the springs for a 3/5 despite how great it looks.
myoung84
myoung84
Tulsa, OK
2012 Power Wagon
I really want some new street tires, but I need to buy at least 2 tires for the Charger first. Not sure why the rear tires are getting so low?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
i wonder why! LOL
IresqU
Virginia
Very nice. I went with the BellTech 2/4 drop on my 4th gen also! All that was needed for me was the factory alignment to bring everything into tolerances. I do rub on the front in rough pot hole conditions or steep driveways. How do you do?
myoung84
myoung84
Tulsa, OK
2012 Power Wagon
I have rubbed a couple times on big bumps, but nothing major, just a little rubbing on the plastic inner fender. I figured it was because of my bigger a/t tires. One thing that has been bugging me is my off centered axle. I want to buy the McG relocator bracket but the ******** wont sell it separate. Dallashotrodparts has a kit to make the track bar adjustable, just have to cut the bar and weld it in.
