Another Bilstein question!!!
Kejar7
Alberta
Hi
I have a 2018 Outdoorsman ecodiesel quad cab 4X4 .I would like to put in bils in the front and rear. My question is with the bils in the front at the 2.8 setting do I put the bils in the back PLUS a 1" Stacked spacer?
Cheers
RAM
BOWERSFJ
Uniontown OH
First, what is your current rake ?
Second, you do know that Bils don’t lift in the rear
You get the front where you want it, then you buy a rear spacer that gives you the final rake you want
Just a word of advice ... Our trucks look best with 3/4”-1” of rake ... Also allows for your light loads
Bushcrafter
I have a 2018 big horn w/ 5.7, I recently had the bils installed on the front. The tech set them at 2.1 ,reason being to preserve the geometry of the front end and not compromise handling. I was going for leveling anyway and not a lift. The truck sets great and handles as good as stock, the rake now is less than an inch measuring to top of wheel well and looks much better.
K
Kejar7
Alberta
OK So I went and did the measurements. 40.25" ear and 37.5" front. So would I assume Bils all the way around? set to 2.8" on the front and the bils for the rear and a 1" spacer?
BOWERSFJ
Uniontown OH
Would give you 1” rake ... Perfect
K
Kejar7
Alberta
Thank you. Now to find the cheapest shipped here to alberta...
joshhhh
