Antenna
RonVez
Ontario;CANADA
Hey all
Triing to understand differances from the Shark Fin vs the Puck style
Is there any install issues if need to change?
Harness reroute?
Currently have Puck
VP3 w/Nav being installed
Thank you
kad
Hudson Valley, NY
5.7L HEMI
The Sharkfin has an extra antenna inside for the cellular connection. (I suspect you knew that since you're planning on changing it). You will need an extra wiring harness that will have to be routed above the headliner and down the A-pillar to the radio. Which harness you need varies on if you have a single cab or a Quad/Crew cab. The link below shows the possible parts for my 2014, I think the 2017 will be the same.
I also see that you're in Canada, I assume your truck was made for Canada? I ask because the Canadian radios are different and usually don't have the cellular system and, iirc, would not need the shark fin antenna. Someone more familiar with the Canadian radio setup may be able to provide better details.
https://parts.allmoparparts.com/aut...-engine/electrical-cat/antenna-and-radio-scat
-K
RonVez
RonVez
Ontario;CANADA
hey
you say cellular connection?take it that's the 911?
wasn't sure if it had to do with gps
no plans to change unless have too
guess we can call it homework lol
Thanks
kad
Hudson Valley, NY
5.7L HEMI
hey
Thanks
The XM and GPS both work off the puck, the Sharkfin is only needed for the 911 and other cellular functions (over the air updates, etc).
-K
LoadedExpressRam
Gulfport, MS
Keep in mind when you update your antenna you may have to change some settings with alpha for gps to work. At least i did.
rotwiler
Washington
My truck didn't even come with a shark fin or Puck type antenna, but I have nav on my vp4 and alpine system, not sure where they hid the antenna.
