anti-spin differential vs electronic locking
CapeFlyer
Looking to order a 2022 Limited 4x4. Will I need to add anti-spin differential or electronic locking rear axle if my objective is stability when accelerating onto wet paved roads? Thx
crazykid1994
If you drive easy you would need neither. The vehicles traction control would do the majority of the work to prevent sliding or spinning of tires. Just be mindful of everything around you and don’t drive stupid when it’s bad weather or cause for low traction situations. LSD is nice to have for circumstances involving one tire off the road or driving on gravel or dirt roads and traction is limited. A true locking differential is beneficial for full on off-roading or racing and is actually worse for wet paved roads because it will reduce traction to one tire while turning because of the arc radius of being different for both rear tires.
CapeFlyer
CapeFlyer
Thx very much. I trading my 2019 RAM 4x2 for a 2022 4x4. I drive primarily on highways in FL. Present truck's traction is usually fine except on wet roads when accelerating - like getting up to speed on an interstate.
crazykid1994
That could be a tire issue. Some tires like the stock Goodyear wrangler sra that came on these trucks were terrible in wet weather and one of the first things I did was swap to better tires. It’s also a tire pressure issue in some cases. If a tire is overinflated you have a smaller contact patch which is bad for traction. I’m in west palm beach.
huntergreen
Marine Corps Navy Badge
Agree with above, your having a tire issue , more so than a traction issue. In your new 4x4 if your truck has 4WD auto, you can turn that in the rain on the entrance ramp.
dieseldave
Little Suamico
anti spin is kind of useless for me . I just put it in 4 wheel drive. Saved myself $500.00.
bm02tj
B C Canada
Order with out then add the Truetrac LSD after as factory unit is junk
Firebird
2019 Ram 2500
I had the e-locker on my 2019, but I would have rather had the LSD
BWL
Embrace the skeptisism
BC Canada
E locker kicks out at around 25mph so limited slip for what you're asking for.
rizzkid12
2021 Ram1500 4x4 Warlock QuadCab 3.92 5.7l V8
5.7l V8 Hemi
I have owned 4 other open rear diff Ram 1500s since 1998 and my new 2021 Ram 1500 Warlock has the factory LSD with 3.92 and the 5.7 V8. I can tell you that the LSD makes a huge difference on wet roads even with new tires Yes the stock Goodyears are bad when worn out, but the LSD makes it a much better truck in the rain and snow both on and off road .
Deki
Phx
The electronically locking rear axle functions as a limited slip when it is not locked. Get the e-locker, if for anything, a piece of mind when you get off road and you start lifting wheels in the air.
IvoryHemi
Illinois
Are you sure? That’s very unusual.
I haven’t heard of an OEM locker that does this since the 2003-06 Wrangler Rubicon. Those were fairly unreliable, prone to breaking.
MAC830203
Beaufort, SC
Magnum 408
What did you order? Lockers are best for rock crawling. I tow a big heavy 28’ boat. Limited slip is best for the boat ramp.
Deki
Phx
It's in the owner's manual for my Power Wagon. I assumed it would be the same on the 1500, but after looking, i was not able to find it.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Your axle has LSD clutches and an e-locker? In a half ton? That's pretty wild.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
Ignore this deleted post. I need more coffee.
