Any way to change this?
DeckArtist
Elmo, Tx
My DS mirror darkens when it shouldn't. At day break and dusk, but not when someone has his brights on from behind!
Badger 13
North Idaho
2013 Dodge Ram 1500
Sounds like it is time to replace it. I know you have a newer truck, but when mine started doing weird things on my 2013 I just change out the mirror glass, and not with auto dimming one. I don't miss the auto dimming at all.
DeckArtist
DeckArtist
Elmo, Tx
Didn't know that was an option....thanks. It's been doing this since it was new.
DeckArtist
DeckArtist
Elmo, Tx
Never asked them about it and factory warranty has expired. I do have the 7yr/unlimited mileage but not sure it's covered under that one.
Administrator
There should be option to turn the mirror auto-dimming off in the settings.
DeckArtist
DeckArtist
Elmo, Tx
There is not unless I am missing something. I have checked every possible setting in the settings and see nothing about it.
TRK_GANG74
Va, Hampton Roads Area
The setting to turn it off is located in the menu with the heated and ventilated seat controls if you have Uconnect 4.
DeckArtist
DeckArtist
Elmo, Tx
I will look at that section, never expected it to be in there.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If you can't find the Off Switch,
The mirror glass is sold by several sources, shop around
DeckArtist
DeckArtist
Elmo, Tx
Found it in the settings for the heated seat and wheel! Thanks so much, never would have thought to look there....turned it off!
