Anybody got a clue?
Pitch1
Backed out of the drive, put the truck in drive like normal. Something didn't sound right. Display shows 4thgear with the manual =/- lit up.
I thumbed it up to D but it almost immediately reverted to 4.
2013 5.7 six speed 19,800 miles
-7 degrees truck had not been started in about a week ,idled about 5 to 7 minutes before placing in gear.
charonblk07
Calgary, Ab
F1-A forged 349ci
Trans is in limp mode, any number of reasons for it. You can crawl it to the shop or get it towed. Any codes pop up?
Tach_tech
5.7L HEMI
Is the CEL on? Did it go back to normal after a key cycle?
P
Pitch1
I was all set up to have it towed in. Went outside started it up and all was normal.
Trouble is it has shaken my confidence.
charonblk07
Calgary, Ab
F1-A forged 349ci
Idling doesn't do much for warming up the trans, so if it's been sitting for a while in the cold it could have been something as simple as not enough line pressure because of the cold trans fluid not moving well enough. I wouldn't worry too much about it at this time an just drive it as normal.
Andy578
Ontario, Canada
2014 Outdoorsman
i remember reading in the manual something about it limiting gears if the transmission is blow certain temps. haven't really experienced it myself except one day when it was -30C it wouldn't let me go above 2nd till it warmed up
