ColdCase
- Joined
- Mar 11, 2016
- Posts
- 672
- Reaction score
- 210
- Ram Year
- 2016
- Engine
- 5.7
When you put it into 4-Auto the axle actuator is triggered and now both sides of the front axles are connected to the diff. *Technically* there is still no torque coming from the transfer case, but this is up for debate (some people say there is 0, some people say there is 10 or 15% even if the rears are not slipping).
In 4WD auto, one of the two half axles is split (disconnected) until the computer thinks it needs to power the front wheels. In 2WD its always split.
In 4WD lock, the axle disconnect is locked in, thats why RAM calls it the locked position, not that the transfer case is locked. Thats why most feel some drag on turns when lock mode is selected, where no drag is felt in auto mode.
You can think of the front axle as three pieces. One section is connected between the diff and wheel, another section connected between the diff and axle disconnect, and the third section connected between the axle disconnect and the other wheel. The axle disconnect basically shifts a spline back an forth on the two pieces of axle to lock them together or unlock them. So one axle half is always connected to the diff as well as the drive shaft, so the diff can be working a bit and depending on where the most friction is, may spin the driveshaft, or may not.
