truckin151
Both the DSP and the SC will give you better transmission performance. The advantage the DSP has though is its custom tuning capabilities. There are not a whole lot of people on the forum who have a fully tuned/custom tuned engine and trans. The engine tunes make your truck nice and smooth, the trans make it run like a beast. I would absolutely choose tuning over ripping into the trans because of the things tuning can do that just doing the shift kit cant. For instance with the shift kit you have to install a resistor to make the line pressure go up, that works fine however it gives you increased line pressure where you really dont need it and shouldnt have it such as OD gears and reverse. With a custom tune (not the user adjustable ones or the ones that come on the programmer, an actual custom tune for your truck) you can get the line pressures increased for each gear individually and so that some can have more or less than others. You can also have the torque converter lock up adjusted, raise your max shift points up to 7000rpm without manually shifting (so in Drive the entire time, mine shifts right around 6600rpm @WOT something you could not do without manually shifting before) at WOT, adjust part throttle points for 1st-5th up and 5th-1st down and at tighter intervals to give you better control over how the truck responds unlike the user adjustments which really only give you control over 1st-3rd and 3rd-1st and larger intervals (the superchips can get you a little more user control over shift points. You wont get that level of control with a shift kit.
I have mine tuned and I can personally say there is a night and day difference between the preloaded tunes, user updated tunes and a fully custom tuned trans. There is no comparison on how the truck reacts and drives between all 3.
