Anyone know this part?
loudnproud
US
First time poster here, long time reader.
I'm hoping someone more experienced can help me identify a part number or even the name of the piece I'm looking at.
I suspect it has something to do with the coolant but not sure. It's rusty and has started leaking a bit and I want to replace it.
I'll upload some pictures here.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
it's a 2011 ram 1500 5.7 View attachment 227798 View attachment 227799
Looks like you're referring to the water/coolant pump
NJMOPAR
Older and faster
ELizabeth, NJ
Heater hose outlet tube on the water pump.
Don't think it's serviceable, probably need the whole pump. Others can verify.
Jeff Strader
"GreyGhost"
Norman Oklahoma
It's a coolant feed pipe for the Heater Core. Replace the water pump and the hose. Flush the coolant out and replace, in case metal fragments have traveled throughout the cooling system.Problem solved
srv1
blasdell n.y
345 c.i. HEMI MAGNUM
on my 04 this is called "water pump inlet tube". it is avail. at rock auto for about 20.00.
srv1
blasdell n.y
good time to ck. all other cooling system componets and do a flush.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Rust on outside means rust on inside......as others recommend.....flush & change pump & stat.
ramrebelx
