OnSale
5th Gen Crew
- Nov 12, 2016
- 3,218
- 1,723
- Location
- Philadelphia, Pa
- 2020
- Hemi 5.7L
09-12 Ram Owners what fuse are you tapping into for the DRL Harness? The directions in the AlphaRex site say to tap into fuse F66 but my 2012 Ram 1500 doesn’t have ANY fuses that start with a F, let alone go to #66 anywhere. I’m guessing the directions are for 4th Gen B Rams (13-18) because the picture of the open fuse box doesn’t match my trucks.
I installed the Morimoto HD Relay Harness and my HID kit works when the truck is off (sometimes) but as soon as I start it, the hid’s shut off. So far I’ve tried the following:
- H7 HID Kit + Stand-Alone Canbus Adapters
- H7 HID Kit + HD Relay Harness
- H7 HID Kit + Relay Harness + Canbus Adapters
The Canbus Adapters by themselves work like 75% of the time, when they didn’t work one light would be out and sometimes two lights.
The HD Relay Harness the lights work when the truck is off, but when I start the truck the hid kit shuts off.
When I tried the harness plus the Adapters it didn’t work at all.
Now I’ve used the Canbus Adapters before for my retrofit with MLED projectors and I also used them in the past when I had my retrofit oem projectors, so I have no idea what’s going on right now. I know they can’t be bad because both sides are having issues and they were brand new so it’s not faulty Canbus Adapters.
The relay harness was a complete failure as well.
What I don’t understand is if you order the Morimoto HID kit from Retroshop, it ships with the Morimoto standalone canbus adapters (I ordered my first hid kit from there and that’s what I got and it worked). But that was the XB35 1.0 ballasts and now I have the XB35 2.0 ballasts so maybe there is a change?
I’m just beat and defeated... I’ve sold many hid kits to 09-12 owners and sent the standalone canbus adapters and never had a complaint, I have no clue what’s going on with my truck but it just flat out refuses to run hid kits.
