Apple CarPlay/Android Auto
Mike Works
Virginia
I have the opportunity to purchase a 2018 head unit with AA and Android Auto. After searching the site the part #68295726AF didn't showup on the list of head units with AA/Apple Carplay. I have a 2016 RAM 1500 L1000006727.jpg1000006728.jpgaramie. I don't want to get scammed.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I have the opportunity to purchase a 2018 head unit with AA and Android Auto. After searching the site the part #68295726AF didn't showup on the list of head units with AA/Apple Carplay. I have a 2016 RAM 1500 LView attachment 550462View attachment 550463aramie. I don't want to get scammed.
It looks strange, almost like a prototype or tech sample?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
The guys said it was installed in his 2014 Ram and it worked flawlessly.
This is not to say it wouldn't work but only that it looks strange.
StateOfMind
Orange County CA
I'm aware, it is exactly what I did. Buying a 2018 more than doubles your need to do so. Buying a different year 4th gen radio is your best chance of avoiding the extra money and labor.
To address the $150-$350 replacements on Amazon and Ebay, I tried 2, and both worked, with one big flaw. Both had the polarizing running perpendicular to the correct orientation. No big deal, right? Right, UNLESS you wear polarized sunglasses. If you do, guess what you see. Nothing. After returning one screen/digitizer combo, finding the second to be the same way, my only other option was to get non-polarized sunglasses.
stooler
What are indications that my 2018 Ram is beginning to experience delaminating digitizers? I'd like to plan ahead for replacement. TIA
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Ghost touches on the screen (button presses that you didn't do yourself)...
StateOfMind
Orange County CA
Also, as the adhesive melts out, there is a visible "shoreline" between the laminated and delaminated sections. When I replaced my screen and digitizer, I had to spend some time cleaning off the adhesive that melted down the radio, and in the mounting area. It's some nasty stuff, lots of alcohol was involved, some of it to dissolve the adhesive.
js12278
Central Illinois
I’ve never heard anyone complain about a polarized sunglasses issue. But hey there’s always a first
I’ll have to read through more negative reviews
StateOfMind
Orange County CA
Take your polarized glasses, turn them 90 degrees.
Also happens on the screens at gas stations. You step out to get gas, can't see the screen. Take off glasses, there it is.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
It happens occasionally when the factory workers make a run with the wrong side up.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
I'm a little late to this one but...
Post # 3881 - Good Info on 4th Gen Ram Panasonic 4c Internal Hardware PNs vs Mopar PNs
PaleFlyer
Charlotte NC
My delam started 3 years before the first ghost press, but was obvious as it looked like the screen was "melting" (as it was)
I did all of this too on my '18, and I would say I spent less than 2 hours total on BOTH the "clean", and the eventual replacement, as part of the LCD died about a year after the digitizer had to be cleaned.
The only "4th gen" radio WITH AA/CP is the 2018, unless you mean the "classics", which I though were technically 5th gen radios, and would require extra work to get into a 4th gen.
js12278
Central Illinois
I just tipped my head and checked my factory screen (I removed the LOCA kept the factory screen) and it did what most screens do, blackened or disappeared. I’m the fix for that is stop tipping your head with polarized sunglasses on. ‍♂️
js12278
Central Illinois
I did the clean up about 3 years ago and am currently noticing shadows along the bottom right now. I’ll just buy a new screen from a reputable source.
js12278
Central Illinois
Of your radio calls your ex girlfriend while your current girlfriend is in your truck, besides failing to block the number, you likely have delamination. Also there will be an obvious bubble across the top inch of the screen
