Steel rope ain’t that easy to cut. It’ll add some minutes to the theftHahaha wow.... Grabs bolt cutters. 5 minutes later.... No cats. Best way to prevent theft is a cat delete![]()
Nah. It’ll slow them down. Ever tried cutting steel rope?
SteelRope is pretty easy just need enough to get the cutter through it and cut both ends it'll slide right ouda the cable. Slide your laser tools 7660 cutter in there tighten it on and start rocking it back n fourth falls out with almost no noise HahahaSteel rope ain’t that easy to cut. It’ll add some minutes to the theft
And, he knits sweaters in his off time.
No you're absolutely right. If I was a criminal I'd either steal it or burn it down out of spite. But that's just me lmao.TO ALL OF YOU WHO SAID THIS WILL NOT STOP A THIEF:
You do not understand the baics of security. It is to tell the thief to go to an easier target. It is not to stop a thief. With enough time and tools a thief can overcome any secuirty devise.
The thief will look under the truck and say - It is easier and safer to go after another target.
Does this make any noise going down the highway?
I mean u probly could but remember if you have the tool or sawzall the cable will likely be more an issue for you than anyone else. Thicken the metal put a cage around it most things work better. People have tested the wraps and the cables they don't work against the common crackhead who's theiving. The best thing you can do is weld your vin into it and weld stolen from and ur number on it. Seen that and anyone who buys them calls the cops on these people as well as calls you.I have a 2500 with 1 cat. I think I could easily use the OPs idea of steel cables idea to protect it.
Yea that doesn’t work in NYSI find it funny people actually keep cats on... Just cut them off and chuck them in the trash.
