Auto window not working for going up
jejb
NW Arkansas
My truck as the auto up/down feature for the front door windows. The drivers side has stopped working for putting the window up. Passenger side window does both still.
It's going into the dealer soon for some other stuff anyway so will have them fix it, but just wondering if there is some quick fix I can do myself.
stimpy433
IOWA
Have you tried do the reset???
"Starting with the driver's front window (if multi-cab) roll it all the way down holding the button and keep holding it for 10 seconds and release. Then holding the button up and letting the window hit the upper stop hold onto the button for 10 seconds more. The do the same with the passenger side. Both should start working again. It's a safety shut off, sometimes if you catch a bump hard enough while using auto-up/down it'll go into default."
joelmic
stl mo
2022 Ram 1500 Big Horn 4dr Quad Cab 4WD SB
Mine have done this several times... usually this time of year since you are rolling windows up and down a lot...
stimpy tells no lie.... it works
MADDOG
Living in a Firepit
6.4L HEMI
Window Switch UP and Hold for 5 seconds
Window Switch DOWN and Hold for 5 seconds
Repeat two more times.
ric221
Mine will do this occasionally. After awhile it will go back to normal on its own
Throwin Plugs
New York
Just do the reset, works like a charm.
While we're on the topic, any idea why this is a thing? I've never had it happen before in any other vehicle I've owned.
stimpy433
IOWA
Safety feature so you don't chop off little Scruffy's head by hitting "auto up" while he's got his head sticking out the window.
joesstripclub
Kansas City, MO
2021 2500 PW
Mine did this the other day but starting working again the next time I drove it. I'll have to remember the reset procedure if it happens again. I also had the exterior button to lock the truck stop working for 24 hours as well.
jejb
jejb
NW Arkansas
That was it. Still learning my Ram-fu, I guess. Thanks
Tach_tech
5.7L HEMI
When you do the relearn you’ll actually hear a click from the door when it’s learned that up/down position. Usually only takes a couple seconds once it reaches the full up or down position.
joelmic
stl mo
And glad it's there for that reason and more... once you know the fix it's no big deal
RGAS
Wisconsin
Mine do it all the time and this is exactly what I do and it works really good for a while.
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
ahhh mine did this one time i thought just the cold weather lol
kscmpr54
[email protected]
Having the same issue with my 2015. Passenger window will go down if you press the switch part way, but if you press to auto it stops and won’t continue down unless press half way. Auto up works fine. Any suggestions? If I press the switch all the way down the window stops so I can’t do the 5-10 seconds after the window reaches the bottom stop.
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
Open it with the switch half way pressed like you do and when it hits bottom hold it. Try it. You have nothing to lose.
Abaco
Virginia Beach
Thank you all for the FIX. The day it stopped working in up mode, It felt like it hit something on the way down. The suggested reset work like a charm. :waytogo:
