Auxilary connector in engine compartment
jbb72
I have a 2018 2500 6.4 Hemi Tradesman. I have searched the forum and the internet. I just left my dealership's modification shop. I cannot find, nor can they without charging me to search for it, the pre-existing Auxiliary Connector for my factory Aux switches anywhere in my engine compartment. I want to wire my own light bar to one of my Aux switches. They can do it for me but it costs $240 labor. Has anyone actually found them or wired something to them?
Thanks in advance
Mulligan1298
US
Did you try rambodybuilder.com? They have info available on the Rams as it relates to chassis cab setups and is for the shops that put aftermarket parts/beds etc on them. I Googled what you were looking for and came up with a few pages that showed where those connectors are "supposed" to be. Most were on the firewall directly in front of the driver, next to the brake fluid reservoir.
Jimmy07
Thanks in advance
The box circled in yellow is the aux fuse/relay box, and the arrows are pointing to the aux output connectors. Do you have any of this stuff? nPtxUAn.jpg
J
jbb72
Thank you Mulligan1298. I will try Rambodybuilder.
J
jbb72
Jimmy07,
My Aux fuse/relay box and my battery are exactly opposite of your picture. That is the picture I found on Rams website somewhere but those light gray and dark gray connectors are not there on my pick up. I wish they were. Thanks for your response.
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
Take a pic of your engine bay near the drivers side close to the firewall for us to see, that will help us help you.
J
jbb72
Here are the pics. Thanks
chri5k
USA
Diesel
From what I gathered on rambodybuilder website you either have to order the truck with the AUX switches which means it will have that connector and the switches. Or an option for upfitter ready which will have just the connector. The wires are actually in the harness but they are blunt cut unless you have one of these options. If you feel the big harness coming out of the firewall on the drivers side you find a big hump in it. The blunt cut wires for the AUX switches are in that hump. They are cut off, folded back against the harness and wrapped to form that hump. There is a kit for installing the connector to the blunt cut wires. The schematic for this harness is on rambodybuilder.
Jimmy07
If your truck came from the factory with the AUX 1-5 buttons on the bottom row of your center stack switch bank, than that relay/fuse box is *supposed* to be there along with the two output connectors. Did you buy your truck used?
Give the dealership parts guy your VIN number, and ask him what the part number of the “control switch assembly” is in your truck, and post the part number here.
J
jbb72
Thank you. I do have a big clump of wires taped together between my battery and my firewall that looks like what you are describing. Would you know why they would put Aux switches in a pick up but not have the connectors already wired? Thanks again.
J
jbb72
Jimmy07
I bought it new and the 1-5 Aux switches were in it when I received it. They are factory installed. I just dont have the output connectors. I will contact my dealership again. Thanks
chri5k
USA
Diesel
That is odd. I have only seen the two I described. Factory AUX switches in the dash which included the connector and relay box under the hood. Upfitter ready with just the connector under the hood.
