Axle gear ratio?
jpilk99
I have a '97 1500 4x4 and the front axle is so rusty that the suspension arm on the passenger side "ripped" off. Can't find anyone to weld it, and told I probably shouldn't. Especially since the whole axle assembly looks ...pretty rusty. Oddly, the rest of the truck/frame/rear axle looks quite good.
Anyhow, as I search for a new axle, I need to make sure I get the right gear ratio. I looked on another Dodge site at a VIN decoder and it says it's either a 3.92 for automatic and 3.55 for manual, and since mine's an auto, ...I assume it's 3.92.
How do I confirm, other than getting whole front end off the ground and rotating wheels & counting shaft revolutions? Is the vin is 3B7HF13Y2VG783365 if anyone is handy at decoding.
Thank you.
Jay
jpilk99
jpilk99
I found the sticker on top of the front axle housing and the tag in the front (though hard to read). I think that number is: 52098819 with 54 610637?
RamDiver
Marlborough, Ontario Canada
2021 DS
I found the equipment listing here, even though they indicate '98+ only.
It shows the rear axle ratio is 3.55 .
I read somewhere that the front could be a 3.54 Dana, but take that with a grain of salt.
Another method of verification of axle ratio would be to use an online calculator.
Search for the transmission gear ratio specs, wheel diameter, and plug in all the numbers.
The results will indicate the RPM at a given speed.
I plugged in a few arbitrary numbers for the 2 gear ratios in question.
The difference is about 170 RPM.
Daw14
South Florida
If it was mine I would service both front and rear differentials.
The rear is staying so it could be serviced and good to go.
The front will be some silicone and gear oil , you could probably come in for less than $20.00 , and some of your time and labor.
This way you can get a visual inspection of internals on both , plus the gear ratio is stamped on the ring gear, so any uncertainty is removed.
Area 51
Oregon
My odometer is running about 20% off of true mileage - I bought this used. Either someone changed my gears or something isn't working correctly. Just saying. A visual inspection of your gears is the only true way to know what's in there.
RamDiver
2021 DS
Check the tires to see if they match the decal on the door jamb.
Chances are, they don't.
Plug in the values at this site, for more information.
AlfaOBD or jScan can tweak things to correct the speedo.
Most Canadian Provinces & US States permit only a 4% variance.
Tominator223
3:21. 3:55. 3.92. The 3 options for that yr. Probably 3:55. But with the age anyone could have changed it. Road trip to da boneyard
