Axle seals leaking
2010 Infantry Vet
Butler pennsylvania
Anyone ever replaced rear axle seals? I know i have to take out the rear carrier to change the seals, but not sure if our rear end has C-clips. Drivers rear outer seal is leaking bad. Is it a pain in the ass to fix, or not too bad to fix?
Tach_tech
5.7L HEMI
Pull the wheels off, brake calipers and rotors. Remove rear diff cover, remove bolt for pin in carrier. Remove pin, push axle in so C clip falls out. Then remove the axle. The carrier doesn’t have to come out, just the centre pin so you can remove the C clips.
No members online now.
Doug70767
