back up cam died
raff18
Sudbury canada
2019c
my back up cam is done for! 2600 km past warranty and dealer won't help me out. anyone know of a cheep place to get a new one or a good used one? funds are tight I'm out of work on a wrongful dismissal.
Damion
2019 Sport
Stupid question, but are you sure it's the camera itself? Checked fuses etc?
raff18
raff18
Sudbury canada
2019c
Ya
The image got more and more fuzzy over the period of a week then all I got was a blue screen.
R.L.K.
Bristol , Tn.
Open your tailgate , remove the large panel then two screws and a small connector .
Remove the camera and Google the p/n I've seen new ones on ebay for 40 -60 $$ the two letters on the end of the p/n doesn't matter .
Moisture kills these cameras sometimes.
Is this a factory install , or added on later ? If later the warranty starts when it was installed .
I'd still check the fuse ... #95 or 96 I think .
If the camera signal died , I'd expect a black screen .
Hope this helps !
baum
savage, mn
2015 Laramie
Hope this helps !
its actually the blue screen if the cam is dead and not black.
LB3711
Trumbull, CT
3.6L V6
Mine went dead a while back. Just a gray screen. It came back when I disconnected the battery . Try that first. I already checked all my connections long time before I did the battery thing. I went weeks with no camera. It was unrelated issue why I did the battery. It was just a bonus
Sent from my SAMSUNG-SM-G890A using Tapatalk
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
Check the connector between the tail gate and truck bed. Some cases the pins get oxidation and stop conducting, just connect/disconnect a few times. Also check the one inside the tail near the handle.
This has worked for a few people.
