Back up camera
Browning A-5
MO
I have read the other posts on here about this issue. I do not know if I can replace the camera myself, Does anyone know how much a Dodge dealer charges to replace the backup camera.
tron67j
Maryland
Digging into your profile, you have a 2025 Ram. Why are you replacing it and not getting it checked out under warranty?
brjed
Birmingham
5.7 Hemi e-torque
The backup camera on my 24 Limited has always had a mediocre image, but the real issue is when backing into a darker space when it's light outside. The inside of my garage is completely black until the tail end of the truck is inside the door. I just appears to be a very cheap camera, which is surprising because all the other cams are fine. Don't know why this one is so bad. Pulling in front first does not create the same issue.
Buhshaun
Merit, Texas
3.6L
You need a light on the rear that you can just light up that garage with!
