Bad gas
ptuttle78
Anyone else get misfire code on number 7 when ever get gas from certain places? Then got gas from Exxon and my check engine light went away
Samb992
Dallas
Mine did that but no codes my wife filled my truck with mid grade and it ran like crap wouldnt shift or nothing put premium in it never had that problem since
tidefan1967
Summerville, South Carolina
A stock HEMI should run fine on any grade of TOP TIER gas 87 octane or higher but especially with 89. No 5.7 HEMI out there should need premium to run right unless its tuned for it. A stock 5.7 doesn't even have the octane tables in the PCM to take advantage of it. You got other problems if that's the case.
P
ptuttle78
Would it be getting time to replace injectors?
buddy guy
alberta
what's the mileage? have you tried an injector cleaning of any kind? i would try some seafoam in the fuel tank. its not going to hurt and may help.
P
ptuttle78
It’s at 112 thousand. I haven’t tried the sea foam yet. I’ll give it a shot. Thanks
buddy guy
alberta
good to hear. i had an older motorbike and it would run a bit rough i think just from age and use. i'd throw a few ounces of seafoam in the tank once a month and seemed to help keep things clean.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
The sea foam seemed to work out. Thanks
Good to hear ! That Sea Foam is good stuff, Used it in my oil before a change and gas treatment for winter storage on my motorcycles !!
buddy guy
alberta
smokes like a sonofagun at first! kind of like it, after the initial shock and you see its dissipating. lol.
22hemi13
Tucson AZ
2014 2500 4x4
No codes on mine. 112-114k 5.7 2500hd miles roughly. Run 87 chevron or shell. If I use anything else it runs but I can tell a diff. No codes. She likes chevron the most no diff in feel or not if I run mid grade
