Took me 2 hrs from start to finish
This is on a 2wd only.
4x4 installs are slightly different. You have to remove these stupid axles that get in the way.
Break the lugs loose.
Lift the truck.
Remove the wheel.
Remove the two 13mm brake caliper bolts.
Remove the cap on the master cyl.
Use a pry bar to depress the two caliper pistons. Remove caliper but don't let it hang.
Remove the two bolts holding on the caliper bracket and remove.
Use your choice of hammer to loosen the rotor free. (If you're reusing the rotor don't damage it with the hammer or mallet)
Remove the wheel sensor and uninstall front the spindle.
3 bolts hold the wheel hub assembly in place. Once removed get your hammer again to remove.
Before installing the new assembly make sure you take a wire brush and clean the spindle really well.
Now reassemble the wheel hub assembly torquing to120ish ftlbs. I say ish because I've found multiple tq specs depending on OEM or aftermarket parts. Use your best judgement. The brake caliper bracket also torques to 120 ish ftlbs.
The brake bolts in the caliper torque to 25ish
Reinstall the wheel sensor.
Bolt the wheel back on to 130ftlbs
Make sure to reinstall your brake cap.
Pump the brakes to engage the caliper.
Bleed the system if need.
Enjoy the $200+ install dollars you just saved if you have the tools to do it.
