Scuba2000
- Apr 14, 2020
- 27
- 21
- Location
- Expat in Italy
- 2014
- 5.7L Hemi
Pre-Wuhan Flu my truck had a catastrophic lower ball joint failure that cascaded. Luckily I had just arrived home and was parking when my driver side wheel decided to basically come off. Has this happened to anyone else?
I ended up having to replace the upper and lower control arms, inner & outer tie rod ends, sway bar links, and CV shaft. I decided to just upgrade both driver and passenger side suspension parts and be done with it. I went with Moog problem solver upper and lower control arms with ball joints, Moog tie rod ends and sway bar links, Moog struts, and a Cardone CV axle.
She is up and running again and feels a lot smoother now. No noise coming from the front end now. Just curious what you guys think about these parts and if anyone else has experienced something similar. Should I also have upgraded the wheel bearings when it was getting done?
Next mod will be ARH long tube headers and probably Borla exhaust. I read the thread on Ramither's install adventure, and look forward to having one similar. Does someone have the Lokar drawing to send in for the custom 31 in dipstick? I have the HP tuner on its way as well.
