ball joints difficult to remove, need help
teddybeartruck
NH
Hi Juro, I assume that by now you got them out somehow. Can you let us know how it went with you?
Blstrick55
Everywhere
I had better luck with a tool like this one the first time I had to get them off my 2010.
OEMTOOLS 27308 Ball Joint Separator, Adjusts from 1-1/8 Inches to 2-1/8 Inches, Fits Common Ball Joint Sizes, Steel Separator Mechanism with Black Oxide Pins
Sirriggs
Pensacola
Curious to this myself. I am looking to doing both upper and lower on my 99 ram 2 wheel drive. It would save me $500.00 so all I would have to do is a alignment. I have watched several videos and other then being a pain, it can be done. Would like to hear how yours come out.
J
JURO
DAVISBURG, MI
2001 Sport.
1500 5.0 liter.
hi
this week I did it. My boss cut my hours to three days a week, so i have some free time.
It was so depressing, i didn't even want to look at my truck for the past year.
turns out the service manual seems misleading to me, guess I was trying to press them out the wrong direction.
See fig.24, how do u remove the knuckle with both of the Ball Joints still in place? I had to use an angle grinder to cut them out.
Then i used the tool that I linked above, it is all i needed. Actually thought about using my gas welding on it to loosen it up but i am glad i didn't need that.
anyway, so happy now :D:D:D
Spike95
Houston
now i want to do the passenger side:D:D
Definitely do the passenger side if you can. Brake, steering, and suspension jobs should always be done in pairs across the axle so you know everything is wearing at the same rate.
Orca
