GTyankee
- Nov 2, 2020
- 12,391
- 17,460
- Location
- El Cajon Calif. 92021
- 2016
- 3.0 ecodiesel
A mechanic at Firestone was about to change out the battery on my Ram
He tested the Old one, while it was still in the Ram
he checked the new one, before it was installed
He did several other things & i inquired why he did not just remove the Battery Posts
then jerk out the old battery & replace it.
He Simply stated, as he worked, that the proper way to make the Switch Over, was to add a Jumper while there was no battery connected.
I was thinking of something like a small Jump Pak ??
( I recall something about a Ram holds a charge when a battery is disconnected & the way to completely discharge the vehicle, was to leave a door ajar or the Lights ON )
The way he was doing it, was Preparation so that the Battery switch was very minimal in Time.
I don't think that from the time he removed the Negative Post from the old battery, to when it was put on the new battery was 3 minutes.
i read something similar to what he was talking about.
I don't know if it applies to 4th Gen Ram DS
When IBS is disconnected from the battery, the device loses its stored memory. When power is restored, the IBS starts a relearn process. Until the relearn process is complete, accurate battery state information is unavailable to other vehicle systems. The IBS relearn process requires three to five normal, operator initiated starts with at least eight hours of engine off time between each start. Usually, the process takes a few days of vehicle operation to complete.
