Battery Issue
BigBassBilly
2003 1500 & 2012 2500
4.7L & Hemi 5.7
Has anyone on the forum had any battery issues?? I just replaced the battery in my 2012 2500 and I'm being told that I should change the plugs for some reason. Any input is appreciated. Thanks.
xrsman
Ontario
3.0 Ecodiesel
How many kms on the plugs now?
I had to replace my battery. I think my air compressor killed it too many times. Wouldn't hold a charge for more than a day at the end.
smoothee
St. John's, NL
Do you have any extra accessories on your truck? Or did your battery happen to freeze? That's what happened to my stock battery after 3 years.
As for plugs, they call for replacement after 30k miles in the service manual. Although many hold off for longer.
xrsman
Ontario
3.0 Ecodiesel
Yeah I had an air compressor that would run continuously when it got to -20 C or colder. The first year I had to it hooked directly to the battery. I eventually hooked it to a switch but it was too late. I also drained it a few times while working on my lights. I had heavy power draw for my lights. Full HIDs 55w and a 55" LED light bar.
Sent from my SM-G930W8 using Tapatalk
