Battery Replacement and UConnect Soft Reset
Jughead
Texas, USA
The battery on my 2019 Ram 1500 Limited crapped out on me yesterday after owning it since brand new (approx 3 yrs 9 months). I found a decent replacement at Costco for $185, so I pulled the battery out of the truck and drove down to Costco in my other vehicle to swap them out. Got home and installed the battery (very easy). Truck started right up, and immediately noticed the "check engine" light illuminated. I also noticed that none of my cameras were working in reverse or drive. All I had was a blue screen with "cameras not available" across the top.
I tried a bunch of different things...all to no avail. Finally, I came across a post in the Ram TRX forum about a soft reset to the UConnect system that I hadn't seen before. It went like this:
1. With the doors closed, start the vehicle.
2. Push and hold the "phone" and "voice recognition" buttons at the same time on the steering wheel for 30 seconds.
3. Release the buttons and shut off the vehicle.
4. Open the driver's door and leave open until the lights go out.
End of procedure. I started up my truck again, and the check engine light was gone, as was the blue screen with "cameras not available." Everything functioned normally. I was ready to go to the dealer, if this didn't work, and was quite shocked and pleased when it did. Just thought I'd pass it on.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
WOW GREAT info Thanks!
That info is good to know
I will be changing my battery soon in my 2015 with OEM Battery !
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
I went out to mine today and it has been sitting for a couple weeks with the dashcam going. Down to 4.5v. It might be time for new ones too and I'm not looking forward to spending that $400 bill.
Hopefully no problems or resets will be necessary but I'll give this one a try if I need to. Thanks.
John Jensen
San Diego County
Ecodiesel
Earlier this year I replaced my 2016 Eco battery and had no problems. It restarted normally. I knew about the restore process but didn't have to use it. I wonder why some have the problem and some don't. I already had the battery so the downtime was short.
Dodge 1500 4X4
Rochester, NY
Did you charge that battery prior to install, it may have a weak charge from sitting, charge for 24 hrs, get a battery tender if you don't use the truck often.
My 2016 Eco-Diesel battery was a quick switch over, less than 10 minutes, i think
JohnPaul
Canada
Jughead,
The exact same thing happened to me this week. (2020 Warlock) Check engine light and blue screen. It reset itself after about 2 hours.
One other thing that happened was between battery changes the truck made the binging noises when there was no battery in the truck or even the key in the ignition. I was worried that the electronics might be gooched and then really concerned when after the new battery was in I saw the blue dash and check engine light.
My service rep said that he has seen and heard all kinds of noises out of the RAM trucks.
Mb7640
Fountian hills az
Jughead,
My servuce rep said that he has seen and heard all kinds of noises out of the RAM trucks.
I will keep this in mind when I replace my battery. Im also wondering if it will go back to normal after a few drive cycles. When I had my challengers after replacing the battery the u cinneft would show wierd things like it was a ram and no or a/c controls except for the manul buttons after 3 drive cycles it went back to normal
turkeybird56
Central Texas
When you pull the battery for more than a short period, it may take several cycles for all the modules to boot back up and talk to each other. Also helps to charge the new battery to full and reset the IBS.
Badger 13
North Idaho
2013 Dodge Ram 1500
I always use a batter memory saver to prevent this type of problem from happening. There are many types out there, but I use mine with a "jump pack" Just FYI for the future.
Rebel4Mo
Billings,Mt.
Had to replace the battery on my wife's 2019 Rebel yesterday.Napa Premium for about $190.
Checked the old battery with a multimeter and it was at 11.3 volts.
New one was 12.5 off the shelf.
Samething check engine light appeared after replacing the battery.Finally went off by it's self.
She told me that the CD player light was staying on after shutdown.Dont think this would cause the battery to drain.
Had to eject the disc to turn off the light.
Bclerks
South Carolina
Battery died this morning on my 2019 Ram 1500 Laramie when I was out and about. Wouldn’t start on a jump. Bought a battery, swapped it out. Truck fired right up. Check engine light is on and my radio package is economy. Missing Uconnect, Sirius, back up camera and other apps. Will the door open button holding reset fix it? Am I forced to goto a dealer for them to download my radio package? Thanks!
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Shut it down, lock it, and let it "go to sleep". It should reboot and refresh after some time. The time varies though.
I am planning on changing my OEM battery on my 2015 soon ! No issues but it is 10 years old !
Will I have same issue with the battery swap ?
Thanks
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Thanks
I'd think not unless you swapped out to a newer 2018+ Uconnect radio.
Bclerks
South Carolina
Radio came back to normal the 3rd time I turned it on (about an 1hr & 1/2 after battery install). Check engine light turned off on the 6th time. Can’t get the IPhone CarPlay to return. Phone only connects via Bluetooth only.
