Battery Replacement Coming Soon
OC455
Central NY
My Longhorn is coming up on 5 years....
Choices for a battery replacement are:
Die Hard H7 Platinum AGM 850 CCA/ 1000 CA
or
Optima Yellow Top H7 880 CCA/ 1000 CA
This is what I can get locally. Anything else I should look at. The Optima is expensive....Die Hard is up there but not terrible. Not looking for cheap...just resonable.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Following as my 2015 still had OEM battery !
OC455
OC455
Central NY
Administrator
Haven't heard of that manufacturer.
They're manufactured in Missouri, highly recommend battery.
The 49-950 is about the largest capacity H8 battery available. I have one in my EcoDiesel.
Even if you don't go with an Odyssey, at least consider the upsize to an H8 AGM.
OC455
OC455
Central NY
Copy that...looks to be the same price as an Optima from what I can see.
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
I had a bunch of points from my dodge card. Used them to get two (diesel) OEM mopar batteries installed. Still $500 for batteries is crazy expensive. My OE batteries in the Gen4 3500 lasted 7 years, just cranked slower than normal.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
If you're wanting to go with AGM you might want to take a look at Walmart. Their EverStart AGM H8 battery is about half the cost of an Optima H7. You get a 90 day return policy if you change your mind (keep the receipt), and a four year free replacement warranty. I've been using EverStart for years and would recommend them.
danielmid
Southeast WI
2015 Sport 4x4
I concur
WY-Dave
Cheyenne, WY
6.7 CTD
Yup that's what I did
clay282
Black Betty had a child... named Betty White
Arkansas
3.6 Pentastar
I popped that plastic retainer out and got one of those Walmart AGM H8’s. She’s been running strong and fine.
I like to check the RC of the battery too
ex:
Die Hard H7 Platinum AGM 850 CCA/ 1000 CA/ 140 Min Reserve Capacity,
Commonly referred to as RC, reserve capacity is the amount of time, in minutes, that a 12V battery can run before dropping to 10.5V. It is measured in reserve minutes. For example, if a battery has a reserve capacity of 150, that means it can supply 25 amps for 150 minutes before the voltage drops to 10.5V.
quickster2
SE Michigan
2015 Ram Laramie 2500 4 X 4
6.4L
When you look at the reviews for the Walmart AGM H7 many state the actual CCA's are 800 when they receive the battery not the 850 as advertised. Can anyone verify this? TIA
Atcer2018
Virginia
The one I purchased in store is 800CCA.
clay282
Arkansas
3.6 Pentastar
At 13.9" long, it would not fit in the tray of my 2023. I think a Group H7 would, by a hair.
Once you pull the battery, there is a plastic piece on the back side of the tray towards the cab. You can put some force on it with your hands and it pops out. Once you pop that out, the entire tray is open and perfectly sized for the larger H8 battery size. If I'm not mistaken, the battery tray is the same for the diesel Cummins as is our trucks and that plastic piece is just there to hold our smaller H7 battery. They are the same price for batteries since the H8 is so widely used. But the extra juice is much nicer to have.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Exactly what I did and spoke about in the other battery replacement threads recently.
Best deal, longest warranty, easiest Country wide replacement if it fails. No Brainer.
quickster2
SE Michigan
6.4L
As long as it is more than your OEM battery, does it really matter?
Diehard Platinum and Duralast Platinum are rated 850CCA. Duracell Ultra @ 800. I have a Duralast 850 in there now that is approaching 6 years. All are adequate for starting the truck. My question was just looking for the answer not trying to go down a rabbit hole over CCA's.
turkeybird56
Central Texas
I run a Duralast Premium AGM H7 in my 2019, that I replaced in February. You have gotten a lot of good thoughts. They all will be OK. If U can go H8 size, that be good also. My Duralast is 850 CCA. I just did not do the H8, did not want to play with battery box. The Duralast is more $$$ than Wally World. Get what works for U.
Duralast Platinum AGM Battery BCI Group Size 94R 850 CCA H7-AGM
