Bds lift and bils
Nick88
If I get a 6 inch bds lift with 5 inch rear coils what will I need to set bils at to be leveled.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
That will partially depend on how much rake your truck as stock. But likely 2.1" and you don't install the preload spacer that comes with the BDS kit. That will give you a total of 7" of lift on the front end and 5" on the rear removing 2" of rake. You typically want to retain about 0.5" of rake to avoid looking nose high.
