Be really careful in the fog
Maligator
Hem 5.7
In upstate New York for work, fog was bad totally misjudged the shoulder. So livid with myself right now12f52b5be77eaf21f6089dba54a7d417.jpg
TXCOMT
What the others here said...you're OK and that's the main thing! Plus, nobody else was hurt, right? Win-win.
BTW, were you running any kind of aux lighting, specifically aftermarket fogs?
TXCOMT
Maligator
Maligator
Hem 5.7
I'm fine and no one else was involved. Super dark unfamiliar roads and bright white lights with fog doesn't mix. Whole passenger side is F'd, just hoping my wheels or suspension isn't jacked. Bad thing is I'm 5 hours from home
WTM75
Upstate NY
3.6 Pentastar
Glad you're ok. Where in NY are you?
Cstan
Rome, Ga
Man, I hate seeing that but glad you're ok.
TXCOMT
OK, that's what I was wondering, lighting-wise...all the more reason to consider true yellow lights for running in fog. I've been debating adding yellow fogs to my Reb and I think your accident is the motivation I needed!
Again, glad you're safe and here's hoping everything gets sorted out in your favor!
TXCOMT
KansasArt
Kansas
Also glad you're ok & hopefully truck only has sheet metal damage. Tidefan hit the nail on the head. The white "fogs" are more of aux lighting set up. Amber fogs work a lot better as its light isn't reflected back at you as much.
Nick@GotExhaust
Supporting Vendor
SC
Damn that sucks. Sorry to hear but glad you are ok.
If there is anything we can do to help let me know.
Sent from my SM-G965U using Tapatalk
BWL
Embrace the skeptisism
BC Canada
I've been in heavy fog that I couldn't see more than 10 feet in front of me. Actually used the GPS screen to give me an idea about upcoming corners. Roadside was full of vehicles in the ditch the next morning. I wanted to stop, but the risk of getting hit stopped was too high. Just turned on the 4 ways and moved along slowly until I was out of it. I could have easily ended up in the ditch with everybody else. Sometimes luck just isn't on your side. At least you're ok and if it was a low speed tip the damage may just be cosmetic.
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Been there. Tully fog in Central ca is brutal. MOST IMPORTANT,,you are OK. Insurance will handle.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
know anyone with a truck that maybe can haul you home? that's going to be one expensive flatbed bill otherwise
:hidesbehindsofa::hidesbehindsofa:
Maligator
Maligator
Hem 5.7
Have some guys I work with say if we can fit it on a uhaul dolly they'll tow it home for me. Hoping it's all just cosmetic which it seems to be but I'm going to have some one check it over and if it's good I'm gonna limp it home
shadowhawk
Southeast WI
hoping for the best.
