belt noise squealing
sloan2007
arlington tn
4.7liter magnum
Hey everybody I got a good one for ya. My 2004 dodge ram 1500 4.7l is making a squealing noise only when it hits 1500 rpm and above. Replaced the belt,pulley tensioner with pulleys , and water pump. Tested powersteering pulley it is fine and alternator pulley is in good condition and they are all lined up. I can not figure it out. Please help? thanks.
S
sloan2007
arlington tn
4.7liter magnum
napa brand but I put a dayco belt on and still does the same thing
S
sloan2007
arlington tn
4.7liter magnum
Thanks man. I replaced the idler pulley though I guess i could get one of those compressor pulley kits and see if that will work.
TexasRammer
College Station, TX
Yeah that could be it, maybe someone else will chime in... I know I sometimes have a squeal when I get over like 2000rpm after I start it up and I believe its the compressor pulley because it wont happen if I turn the compressor is on
S
sloan2007
arlington tn
4.7liter magnum
i forgot to tell ya that it only squeals when its 65 degrees or colder outside weird uhh
Bscanlon64
Same thing is happening to me. Same temp and everything. Only does it for a few minutes after start up, but yeah anytime you give it gas, it squeals.
SmokedRam
Zephyrhills, Florida
Take your belt off, and take take a wire brush to all your grooved pulleys, then reinstall the belt and see if it still does it.
S
sloan2007
arlington tn
4.7liter magnum
okay I took my belt off and took a wire brush and cleaned all that crap out off the grooved pulleys and also cleaned the belt now i have to wait until it gets cold again which will be monday and I will see if the squealing is gone. cross fingers
SmokedRam
Good deal, if the grooves had junk all up in them, the belt was more than likely slipping on the pulleys.
S
sloan2007
arlington tn
4.7liter magnum
well it was gone for a day but its squealing again! driving me crazy man
S
sloan2007
arlington tn
4.7liter magnum
put some dish washing liquid on the belt and the squealing is gone
S
sloan2007
arlington tn
4.7liter magnum
napa v rated belt tried a dayco belt it does the same thing and the dish washing liquid only worked for a couple of days
S
sloan2007
arlington tn
4.7liter magnum
Found the problem the dayco pulling was bigger than the factory I put a new napa pulley on and the squeal went away
