Best looking AT tire that won’t break the bank?
Trevorjohn
Ohio
Looking for some 305/55-20 AT tires that won’t break the bank. No this is not a WTB thread, just looking for your opinion on the what the most visually appealing AT tire is that isn’t crazy expensive.
Thanks!
troutspinner
Gilbertsville, Pa
2026 Rebel G/T
Hurricane
Without breaking the bank I would assume Nitto’s and BFG are off the table. I have seen Generals on a Ram and thought they looked really good.
kballousr
McKinney, TX
I have used Nitto's on my last 2 Rams. They aren't that expensive but wear really well. Just bought a 2019 Limited 4x4 and about to go back to them. Trading mine in at Discount Tire.
13ram1500crew
Ontario
HEMI
The the most expensive of them all lol.
What is your budget?
The Terra Grappler G2s are significantly cheaper than KO2s, but also you get Generals for cheaper the the G2s.
$14 difference per tire isn't terrible between the BFG K02 and the Terra Grappler (Discount Tire)...The extra $60 is more than worth it in my opinion, but you are right, there are cheap tires like the Hankook's that are only $160 a tire or the extreme other end pro-comp tire that is $295 each....I spent a lot of time researching and found the KO2 was the best deal for a tire will last for more than a couple years. Here in canada all tires are expensive, along with everything else.
John813
Based off tirebuyer, DTD and tirerack
1. Pathfinder AT ($249)
2. Falken Wildpeak AT/3W ($255 per)
3. Nitto Terra Grappler AT ($283)
How they wear/ride/quality or actually look in person? Not sure.
Tirerack is selling some 2015 production Goodyear Wranglers for 229 a tire.
Tirebuyer is offering 10% off nittos with a code
@13ram1500crew
He's looking for 305/55/20s
adrianp89
Tampa Bay, FL
Hmm must have went down. It was about a $400 difference for a set when I researched a few years ago. Another deciding factor for me was weight, I didn't want to loose too much MPG, and I think the KO2s were ~10lbs heavier per tire over G2
13ram1500crew
Ontario
HEMI
Yes, they are very heavy tires. Something like 51lbs each if i remember.
Trevorjohn
Trevorjohn
Ohio
I was trying to stay under $1000 but if i go a little over that’s not a huge deal. The falkens seem the most appealing so far.
BWL
Embrace the skeptisism
BC Canada
Not sure about available sizes but were you hoping for something off brand like the hercules terra trac at2. Looks like they arent cheap anymore so disregard.
bradstephens25
