Best mods for 4.7
woody31
texas
4.7 Special Service Vehicle
Just like it says,,,what are the best bolt on?? Already dropped in a k/n air filter?? Like exhaust and a tuner..?? Thanks
JAMMAN
Hi, I see there has not been an answer yet here, probably for a reason. As an owner of a 4.7, having dealt with a hand full of the common text book 4.7 problems, the best thing you can do for your 4.7 is sell the truck with the 4.7 in it and get a similar one with a hemi.
I love my truck because the body is in great shape and knew nothing about the heritage if you can glorify it that much regarding this 4.7. I have put a lot in to my 4.7 but still monitor oil pressure and do not trust it, even though the oil pump was replaced.
You can replace it with a crate motor that has all the errors fixed, but probably less expensive and less headache to just trade it. Sorry for the grim outlook but this is from experience.
MarkV
Ontario, Canada
4.7 Magnum V8 NOW with Moose Power
If your gonna keep the 4.7 get a chip. That will give you the most performance for your $$.
woody31
woody31
texas
Thanks for the?e replies,,and although I'd love a 4 door with a Hemi. ,,I'm married to this one. My sister gave me this truck,,its a old retired police truck, complete with push bar and spot lights,,it was a Texas state hiway patrol unit. It runs great and with only a little over 66,000 miles I feel it will last a long time properly cared for,,I guess I'll do a y pipe and a decent muffler and call it a day,,thanks again for your time.
woody31
woody31
texas
Any recommendations??
Statcher1
Kentucky
A set of gears would be a good start. But that would hurt your highway mileage. Then you could move on to the tuners and cold air intakes. Followed by headers. I'm not sure what brands support the mods for the 4.7 trucks though.
woody31
woody31
texas
It has 3.55 gears in it now,,
Statcher1
Kentucky
If your wanting more pick up and performance. Adding a set of 4.10 or even a set of 4.56 gears would greatly improve your performance. But they would definitely hurt your fuel mileage in the highway. And if your 4x4 you will have to double the cost of the investment.
woody31
woody31
texas
It has 3.55 gears in it now,,and has a 5 speed auto trans,,
Any recommended y pipes to look for...and what muffler would be best,,,thank you..
justin13703
MD
3.55 gears are horrible for performance. Especially with a 4.7. That's why people keep telling you about 4.10 or 4.56 gears
HemiLonestar
Navy Badge Coast Guard
MD
3.92's at least.
Joshua
4.7 Magnum
How hard and expensive is it to change out these "gears" you all keep referring to
2003 Ram 1500 4.7 magnum 4x2
196k miles but well taken care of.
JAMMAN
If you have to ask, then you should probably grab a buddy that is in to this stuff and buy him a 6 pack and a big mac to help you out. You will need gear lube and a gasket for the cover also.
Joshua
4.7 Magnum
Indeed my buddy is this place, could you maybe point me into the direction that I need to start and from there I will read myself sick until I too can change such madness from the side of the highway to hell
woody31
woody31
texas
Any links or suggestions on where to get a set of 3.92 and how about a posi/limited slip
HemiLonestar
MD
Two options, install/get installed replacement gears into your existing rear or find a junkyard one that already has those gears (cheaper but unless you buy it from some you trust you don't know the maintenance history or condition).
woody31
woody31
texas
Thanks for all the replies..I checked moes and a few other online performance companies,,looks like ill be headed to the pick and pull,,looking for a rear end and a set of electric fans,,what fans will work on these trucks??
icywhite
missed this dont get on much but i have had just about every bolt on for the 4.7 if you look at my mod list to see what can be done to the motor. on a 5-speed i would start with gear 4.10 if you do alot of highway driving 4.56 if you dont follow that with a 2008 intake will make a good start. you ask about the y it will help but if you havent done anything else with the exhaust it wont help much
noraa73
