Best Mods for Under $100
ISKRA
Tacoma, WA
I found a used bedrug for $80 and put on the $25 deezee tailgate assist. Might get a shorter antenna but wonder how it affects reception..
I was very skeptical of a short antenna after taking a year of antenna theory in school, but I was pleasantly surprised with how well it worked. The lower range of FM had minimal distortion and no difference at the rest of the FM spectrum.
AntennaMastsRus - The Original 6 3/4 Inch is Compatible with Dodge Ram Truck 1500 (2009-2020) - Car Wash Proof Short Rubber Antenna - Internal Copper Coil - Premium Reception - German Engineered https://smile.amazon.com/dp/B01M6CAZKK/ref=cm_sw_r_cp_api_i_qb8gFbFGR1NAJ
SitKneelBend
St. Louis
3.6 Pentastar
It will lower reception. Depending on where you live it will vary on how much you no longer can tune into.
RangerWeaver
Lancaster Pennsylvania
V8 4.7L
I recently (almost a month now) purchased a new to me 2011 Ram 1500 Crew Cab SLT, after owning a few vehicles after having to say goodbye to my 1996 Ram 2500.
After reading all 241 pages I have a few new ideas and came to realize that this is an expensive thread.
  • I have already replaced the halogen H13 bulbs with Led replacements ($39.99).
  • Installed two (will be more) small amber led pods in the grill ($15.00)
  • Installed an Led floodlight behind the grill (free as I had it from my chevy), I do plan to add another.
  • Installed low profile stake pocket anchors in the two open pockets (free as I already owned them).
  • Mounted my CB antenna to the driver's side stake pocket behind the cab ($18.49 for the mount).
After replacing the passenger side headlight116130612_1643538519134541_1273043679933344220_n.jpg 109532835_287065999408901_6091099022913367870_n.jpg 116075352_1704675339694778_82699315836555755_n.jpg
I have planned
  • Cabin air filter
  • tailgate assist
  • Led floodlight pods for reverse lights
  • bed mat
  • Led bed lights
I also have a mod planned for this Wednesday that is over $100, as I am planning to replace the stock base radio with a touch screen radio with GPS and install a backup camera that replaces the tailgate handle all for $445
Anonymous007
KY
After replacing the passenger side headlightView attachment 216765 View attachment 216766 View attachment 216767
I have planned
  • Cabin air filter
  • tailgate assist
  • bed mat
  • Led bed lights
Keep updating!
Anonymous007
KY
duckman631
New Jersey
2016 Big Horn Crew Cab
Hemi 5.7 K&N Cold Air Intake.
Anonymous007
KY
I've been running a set of those for a few years. Make sure you squirt a little Fluid Film or similar into them to keep galvanic corrosion from fusing them onto the valve stems.
-K
Thanks for the tip [emoji106]
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Anyone know of a way to change the trim pieces colors? Would like to have mine a blue that matches the truck and not peel off.
NJMOPAR
Older and faster
ELizabeth, NJ
Go to carid.com and check out the Remin dash kits.
They have lots of colors & finishes. I have the African Zebrawood and it's top notch quality.
