Best spray paint match for PW7 (bright white)
JColdIron
Triangle NC
Have some areas on my 2012 Ram 1500 SLT that need touching up due to wear at the door sill and chipping from trailer jack on tailgate that the PO inflicted.
Doesn't have to be perfect as its a work truck but Id like it to look the same color at least!
Anyone have success with any of the off the shelf brands either at the hardware or automotive store?
Daw14
South Florida
Automotivetouchup.com , any paint will probably be a little bit off color from your trucks paint fading over the years.
J
JColdIron
Triangle NC
So no Frigidaire white?:D
No aerosol can of reasonable likeness? The automotive touch up version looks to be over 30$ for a can. If I need to spring for it I will but I wanted to be sure
Treburkulosis
Glorified Car Washer
Haslet, TX
I was having bad trouble matching my 02 Camaro. I used Mahopac auto paint. The area I had to touch up you can not tell that is ever there. It matched 100% perfect.
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
NAPA may still, but I know used to, mix up aero cans based on color code.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
