Better then a timing locked out Phaser,if you're doing a bigger cam
Smith Innovation is at Smith Innovation. ·
Follow​
4h ·
Home of the one and only billet sprocket timing set & phaser eliminator for the VVT Gen3 hemi. Ruggedly tested to over 1650 hp with an entire season of runs already.
Priced below a OEM phaser (locked out) and without the potential failure of the sheet metal sensor cage and/or phaser mechanism while loosing over 2 lbs off the cam nose. Upgraded attachment hardware and better clamping than OEM.
Demand this upgrade on your next swap/race build. In stock and ready to ship.
W
This is what the phaser looks like when it fails.This is my buddies old phaser off his Hellcat.It's an expensive fix if the phaser comes apart :rolleyes:
W
Does that eliminate variable valve timing?
Yes,but the majority of bigger aftermarket cams lock out the phaser,so you don't have VVT.It's done to help prevent piston to valve clearance issues as the hemi's an interferance engine.
If you look up the upper cam gear for the earlier non-VVT 6.1's,this is very similiar to their cam gear.
W
I might just have to sacrifice my original one
If your original one was still functioning,i'm not sure i'd hack it up just to find out,lol. I'd go looking for one,that somebody has messed up trying to do a limiter or lock out on,and the spring has come unwound,then you don't mind cutting it up,as it's virtually garbage after the spring has unwound ;)
W
Ed i'd throw your old phaser on market place,as it'd be a good one to use with a lock-out installed.I'd buy it off you ,but the shipping to me would probably make it worth more then a new one :rolleyes:
EdGs
FL
Even with 200k miles on it?
What should I ask for it?
53022243AF goes for $317 @RockAuto
W
I'd start at $200,that gives you some leeway to come down.There's always somebody who tries to install a lock-out or limiter and buggers up their phaser,by loosening the last bolt to much and the spring comes unwound.Once the spring becomes dislodged the phaser is basically garbage ;)
mdc1990zr1
Conshohocken, PA
If you eliminate the VVT, should you start with an earlier block that had the camshaft lower in the block?
W
If you eliminate the VVT, shot you start with an earlier block that had the camshaft lower in the block?
6.1 blocks aren't easy to come by now,plus they're a bit harder to get cams for,as not all that many outfits are doing cams for them.A 6.1 block done to 405 or 411 cubes would be a nice engine for a daily driver though
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Smith Innovation is at Smith Innovation. ·​
Follow​
4h ·
By chance does anyone know when the CEL gets tripped using a lock or limiter? I imagine it has to have a min/max it looks for but I don't know.
W
I think it probably has a max allowable movement number, min would probably be "0" degrees of advance or retard aka:straight up,and as long as the cam and crank timing are with-in that max allowable movement number it won't set a code.A limiter or lock-out are going to keep the cam timing well with-in that window of allowable movement.
I've never heard of anybody getting a cam/crank code using either a limiter or lock-out,but if you're a tooth off on the cam timing it will set a code,so being a tooth off,must move the cam out of timing far enough to set a code.
Supposedly there's about 38 degrees of total cam movement,whether that's all advance or retard or a split of the two,i'm not sure
I'd think they'd use spring pressure to advance the cam,and oil pressure and rpm to retard it,but that's only my thinking, i might be way off in left field,and totally wrong in thinking that's the way they control the cam timing :Big Laugh:
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Doing a cam has always given me pause because I'm afraid of that check engine light. If I can't pass emissions it's not going on my truck. Good info for the future. Thank you.
W
As long as the cam and crank are in time,i don't think a limiter or lock-out will cause any codes.
