Bilstein 5100 2.1 was no good
KahneFan
Buda
EDIT: It was a bad install, as suggested below. 2.1 is prefect and these are great!
I did a lot of looking around and people all seemed to say to set the bilstein 5100's at 2.1 (2nd to last notch). So, I took them to my local shop and asked them to do just that and the outcome was my front end was higher than the rear... by a good 2".
2013 5.7 8 SPD 4x4
DRkNESS
South Jersey
Oh wow, that is quite the difference. What did they do to correct that if at all ?
skirider
Yup that way off. They messed up. My 2.8 setting does not even look that high
Ricks Ram
Yea sounds like they put the spring plate in upside down. How in the heck did the get the spring to collapse that far??? I can't think if anything else that could cause this.
KahneFan
KahneFan
Buda
They put the bottom plate upside down. This has happened many times. 2.1 should give you a 1" higher stands in the back.
They called back, that's exactly what happened.
poweredbyhemi
Are these as bad on dodge rams as they are on f150's?
I had 5100's on a 13 fx4 & that was not a good setup @ all.It looked good but rode like chit,far worse then stock.
skirider
Rides better than stock
R.L.K.
Bristol , Tn.
These ride better than stock ! Something was either #1 wrong on the install or #2 bad manufactured shock ...
KahneFan
KahneFan
Buda
It was a bad install, as suggested above. They're great!
