Bilstein 5100 series Rear Shock 09-14 Ram 1500 4WD 0-1" Lift
csokol83
2013 Ram 1500 SLT 4x4
Hello all, I have a 13' with RCX 6" and 3" BL. Can I upgrade the shock system with a set of Bilstiens all the way around? My plan is to put the front at 2.1 taller and use: TGC-1.5" 09-14 Dodge Ram 1500 4x4 Rear Steel Coil Lift Spacers along with the Bilstein shocks. Is ths possible?
All input is appreciated
iam_canadian22
northern ontario
No issues with the front if your kit uses a strut spacer , for the rears they will be too short unless they sell some longer for lifted applications ive never looked into that though so dont know for sure, and the tgc spacer would likely work if your kit doesnt already use a spacer for rear lift
h2oman
SoCal
Yes. Bilstein makes them for lifted trucks. You just need to get the right ones.
