Bilstein 6112's settings - Upper control arms needed?
16WhiteQC
Hudson valley, NY
My original thread from years back where I installed them @ 1.3 for ref. - https://www.ramforum.com/threads/bilstein-6112s-1-3-and-fox-2-0s-installed.108971/
Kinda getting inchitis and have been thinking of doing upper arms and raising the front while I am there since I am due for an alignment and have new tires going on (stock size).
I have been looking at going to either the 2" or the 2.4" setting, putting daystar 3/4" spacers in the rear and may be an adjustable tracbar.
So the real question is should I just do the upper arms while I am there due to the age/mileage (84K)?
FYI these are the arms I am thinking based on what I have read (I.E. this is a one and done for me) Hate the red so I will have to paint them - https://jbaoffroad.com/jba-upper-control-arms-for-2006-ram-1500
Other option but $$$ - https://www.thurenfabrication.com/p...6e08cd7450cbbdddc64c6cf2e8891f6d48747c6d56d2c
Thoughts?
CanuckRam1313
Ontario Canada
2023 Warlock
Thoughts?
If you're going to do it, go with the Thuren UCA's, a top tier supplier for the track-bars, and look at the Hellwig adjustable rear sway bar as well.
Spend once & cry once ;)
Nick@GotExhaust
Supporting Vendor
SC
If you are looking in that price range, I highly recommend the Core 4x4 UCA's. They have been great. Thuren is great but more for 2500/3500 trucks. When it comes to UCA's, control arms, track bars, etc...Core is hard to beat! Message me if you would like a quote on anything
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
danielmid
Southeast WI
2015 Sport 4x4
You've also got Zone, Icon, BDS, Freedom Offroad to name a few more. Here's a handy (maybe out of date a bit) part reference guide post:
Jeepwalker
WI
2012 Reg Cab, 4x4
If you decide to stick with stock ride height, I'd go with TRW UCA's. But check your lower ball joints b/c they are kind of the weak link in the suspension. TRW was the OEM for UCA's and after 190k miles, the B-J's on mine even after removed are still pretty 'tight'. I replaced them with Mevotech solid arms ...but I'm on the fence if I'll keep them or go with new TRW's before I have it aligned. Everything else I replaced with TRW.
