Bilstein at 2-75 question
Truckie707
Hey guys just got a set of bils 5100 gonna instal at 2.75 what size spacer is everyone using when setting them to max ?
Solid State
2011 Bighorn
Are you asking about using a rear spacer as well? It all depends on how much rake you have now, and how much you want when done. Bils maxed should put you about dead level. Some guys will add a .5 spacer to retain some rake. Just depends on what you want.
T
Truckie707
Ok thanks didn't want Want to have the front higher than the back I def wanna keep a small take so I'll look around for a small spacer for backs
smokedbystang
Central Florida
2012 Ram 1500 Express 4x4
I set mine at max height and still have a 3/4" rake. My rear height was 39 1/2" and now the front is roughly 38 3/4". No spacer needed for mine.
MaizeNBlue
If you want to keep some Rake, why not set the front ones at 2.1" ... will leave you roughly 1/2" Rake .... no spacers needed .... I'm pretty sure you don't need spacers if you set them to max, which is 2.8"
