Bilstein at front at 2.8 and what for rear??
Activate
The Netherlands
2015 and 1998
360 and 410 with SC
Hello,
After reading a lot about a 2,5"spacer I have decided to go with the Bilstein 5100 in front instead of the spacer.
For the rear what do you guys recommend to get a lift in the rear for 2"?
Just a spacer on top of the spring or a better and longer coil?
The ram (4x4) has only 50.000 on it with the heavy duty shocks so the rear ones must not be too bad I guess, not seeing terrain at all only pavement.
Thanks and greetings,
Erik.
azcoyote
Phoenix
Keep reading the lift forum and the sticky. Lots of info about the 5100s. Maxed at 2.8 you will want upper control arms. Measure your wheel wells. On mine, 2.8 would leave me .4 high in the front. How you use it, what tires, etc, etc, will help you decide on spacer rear, or lower front.
Nick@GotExhaust
Supporting Vendor
SC
Highly recommend going with the Eibach Pro Lift kit instead of the 5100's. They will ride better and perform better. Also you get 4 new shocks and coils! Then I would look into the Zone UCA's. Great bang for the back with them.
Message me if you would like a quote on anything
Activate
Activate
The Netherlands
2015 and 1998
360 and 410 with SC
Wit the Eibach kit I only get 1" lift in the back?
eljefe
Moyock, NC
I didn't need UCAs with my 2.8 Bilstein lift. They look just as even as when the truck was stock.
brad_12
Independence, WI
Hey Nick now that the Eibach has been out for a while and having customers running them how would you say they compare to the Bilstein 6112s?
Nick@GotExhaust
Supporting Vendor
SC
I would say the Eibachs have better road manners but the 6112s are a little better off road. I would recommend still doing something for the rear suspensions if you do the 6112's.
Kgibson1315
Mayfield, KY
I installed the Bilsteins at 2.8 and added a 1in spacer for the rear.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
I have Bils at 2.8 in front, added TGC 1.5" rear spacers, and also put in Fox 2.0 shocks in the rear. Handles much better than stock, but I can't comment on how it differs from a 6112 or Eibach setup.
LVnight1500
bils at 2.8 in the front + 1.5" icon coils w/bils shocks in the rear = level perfection :)
LVnight1500
Yup. It's mounted on Black Rhino Sprocket 9.5" 0 offset
dterrel
