Mitag3
- Dec 27, 2015
- 46
- 11
- Location
- Eastern Nebraska
- 2014 Ram 1500 Express
- Hemi 5.7
So roughly 1 year ago I did the front Bilstein 5100's on my 2014 Ram 1500 Express 4x4. I set them up at 2.1" of lift, have had no problems since. Yesterday I noticed some squeaking driving down the road and after investigating I noticed the shaft of the strut was sticking up quite a ways higher on the passenger side than the driver side (under vehicle weight). The spring cup is still in the normal spot so the truck is still sitting level but the squeak is quite annoying and I'm sure this amount of movement will cause damage eventually. For reference the top of the strut bolt setup on the driver side is basically flush, which the passenger side will return to when the vehicle is jacked up and the weight is removed from that spring.
I can't upload the videos at the moment, may try and upload them to YouTube and link them but basically when I jack the front passenger wheel up I can watch the strut move slightly side to side and raise up that roughly half inch, returning when I lower the wheel back down. No play in bottom bolt of strut, and all 3 bolts holding the upper assembly in position are tight. Any ideas?
Under vehicle weight
Under vehicle weight 2
Vehicle lifted
Vehicle lifted 2
Vehicle lifted
Vehicle lifted 2
