Bilstein vs. Rancho on the beach.
Which is better on the beach a) Bilstein Adjustable, or b) Rancho Quicklifts
  • BILSTEIN 5100 Series Ride Height Adjustable
    Votes: 11 78.6%
  • Rancho Quicklift Suspension Lift System
    Votes: 3 21.4%
  • Total voters
    14
jbr
Long Island, NY
I would like to get some feedback regarding leveling my 2013 CC SB with 5,000 miles. I plan on taking my family and truck out on the great beaches we have on Long Island this summer.
What would be the best way to level my truck between (a)BILSTEIN 5100 Series Ride Height Adjustable, or (b) Rancho Quicklift Suspension Lift Systems?
Should I do all four corners to handle the ride on the beach better?
Tires will remain stock 33" for awhile.
Current stock rake is 2" (front 37" and rear 39")
The beach will be the only off-roading that I will be doing.
Would I have to replace the upper control arms with either set up? Seems there are ball joint issues going around with leveling 2013+ trucks. My build sheets states "April 2013".
Any input and suggestions would be greatly appreciated!!
h2oman
SoCal
Just go with the Bilsteins. They've got the racing heritage. Rancho doesn't race so they're guessing at their valving and dampening. Since you won't be saving money why not go with the better product.
iam_canadian22
northern ontario
sorry I cant help you on shocks but those that have one or the other all love them, unfortunately not much info for comparisons on ride quality, as for upper control arm im afraid you'll likely need to change it, the only 13's ive read of being okay had build dates from 2012, zone offroad is your best bang for buck for those
h2oman
SoCal
I agree. Zone is the best economy choice. IKON is great but very expensive.
Riding on the beach, I am sure you want travel. That is why they went away from solid axles and opted for the *** weak suspension that almost all 1/2 tons have from about 1980 and on up. Great for dessert racing and freeways, and bad for just about everything else from alignments to real wheeling to replacing a million damn bushings every time they fail or squeek. So, double check this but I believe the Rancho preload has a spacer but similar coil length to the bilstien, however because of the spacer the rancho will have less travel as the shock travel will be shorter by about 1 inch, meaning the 5100's will have more travel and will be a much better ride on sand.
5100 versus preload
h2oman
SoCal
5100 versus preload
And everywhere else. I think what has happened over the last couple of months is due to Bilsteins shut down of production. People wanted their levels so bad that they were willing to spend more on a lesser product than be patient and wait. One company wrote the book on monotube design while the other made cheap aftermarket twin tube junk that they copied from other companies. Bilstein screwed up and let in a market share that should never have happened. If you can't wait and want to spend more money get the Fox coil overs.
jbr
jbr
Long Island, NY
Thanks for the input. I am not in a rush to level my truck. Fox seem great, but out of my price range. I want to be an informed consumer and do it right the first time.
h2oman
SoCal
From what I can see Bilsteins are back in stock.
freddyx844
North Yorks. UK
Hemi 5.7 on LPG
Excellent, I'm waiting to import them to level my truck. I'm changing all 4 but the front levelling shocks are on back order.
Sent from my GT-I9100 using Tapatalk
lone12star
Kyle, Tx
Looks like I know what I'm ordering on payday
Sent from the MOPAR gods!
jbr
jbr
Long Island, NY
Just ordered the Zone UCA today
Did you order the Zone UCA because 1) you are currently having ball joint issues or
2) preventative maintenance so you don't have issues down the road?
How is your truck leveled?
jhettinger79
Fort Worth TX
Truck is leveled with a HBS spacer 2.5 right now. Just for preventative maintenance so I don't have the ball joint issue in the future, I will be replacing the spacer with Bilsteins next week if they ship. Plan to install the UCA and the Bilsteins at the same time.
BMD
2015 x1 and 2014 x2
The ride is great with the Rancho and no issues with ball joint in either truck so far.
mel5151
2010 Ram Laramie 4x4
I just put rNachos on and yeah, the ride is great. I went with it because I valued dampening adjustability over ride height adjustability, and I didn't want to reuse my old springs with new shocks. Both are great options, and really comes down to what sort of flexibility you want out of them and how set you are on your level height choice. Personally, i think the height difference is negligible enough to notice and you would probably have more fun figuring out and dialing in the best dampening setting for your use, beach, trail or pavement. I do. Good luck.
Sent from my iPad using Tapatalk HD
jbr
jbr
Long Island, NY
Did you do all four corners? How often do you change your dampening.... each time conditions change?
I'm still undecided..
h2oman
SoCal
Just put the Bilsteins on and you never have to think about it again.
