Bilsteins with 6" lift question
Rzrman328
The treeline
-18 you should be ok.
Someone with this setup might chime in.
Drummin4jc
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
How hard would it be to put a 1.5" Zone body lift on this whole I'm doing the lift install??
Adam
smoothee
St. John's, NL
Definitely agree with these fellas. I've got 5.4" in the front and 3" in the back, and my 35's are borderline.
Thatdude596
buckeyes state
2009 ram big horn
do not do a 6 plus body lift...if u decide to do a 6 plus body lift I have a set of fuel mavericks on 37x13.50 with less than 2k miles for 2200. setup is 3200 new, zero issues....just saying
bodyman247
wichita ks.
5.7 415 hp
I have that exact setup...6" rcx with bils all the way up to 2.8 just to get level.
kg93
AZ
yeah i have a 6" lift 2.8" bills and a 3" body lift with 35s and im dying for some new gears and 37s or 38s
Thatdude596
buckeyes state
2009 ram big horn
wow no offense but truck looks small for my same setup. what's measurement to bottom center of fender flares
something doesn't look right. did u install both?
Thatdude596
buckeyes state
2009 ram big horn
similar setup
Drummin4jc
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Well with this all being the case, I did find Toyo Open Country R/T 37x12.50x20 for less than 35's in M/T. I really like the R/T tread pattern. So I think I'll do the 1.5" body lift with the 6" suspension and run those 37's with the advice you guys gave. :favorites13:
similar setup
That's a 3" body, right??
Adam
Thatdude596
buckeyes state
2009 ram big horn
Adam
Yes with struts maxed on front and a 1.5 rear coil spacer in rear as well
kg93
AZ
its the angle + the front is pulled down from the bumper and you have that spacer in the back, i dont
alphaprojects
