binding cv shaft issues
jdeere05
Indiana
Since truck it leveled or lifted bought it that way cv shafts are binding...what's best way to possibly fix this
NYCruiser
Yonkers, NY
Depending on the setup, I've heard some kits have drop brackets for the front diff to lessen the angle on the cv's. Maybe you need something like that.
charonblk07
Calgary, Ab
F1-A forged 349ci
Drop bracket like NYC said or a set of high angle inner CV joints from Kore. The drop bracket will be cheaper.
Knotts89
Montvale, Va
Has anyone ran kore cvs? I been thinking of buying a set here soon but can't find a lot of reviews
jdeere05
jdeere05
Indiana
After the drop bracket I'm guessing that I will have to do an alignment again
charonblk07
Calgary, Ab
F1-A forged 349ci
I run a set but for a different reason. I'm dropped 4" in the front on a 4wd, which is the exact same angle as going up 4" with a lift. I grenaded my stock CV joint 5 minutes after I started the truck but the Kores have been going strong for 2 years now with no issues.
Knotts89
Montvale, Va
That's good to know because i have 6 inch suspension lift and bilstein shocks set at 2 inches. No real cv problems yet but i rather be on the safe side
Knotts89
Montvale, Va
But he will have to pull the suspension off to put the drop bracket on the diff wouldn't he? If he has to pull the suspension i would recommend a alignment its cheaper than buying new tires
